Please suggest some upgrades
Old May 15, 2012 | 03:39 PM
t_jones792002's Avatar
t_jones792002
Hello all! I'm new to the 7.3L and haven't had a lot of time to research the many upgrades there are for it and I am wanting known/proven combinations to make to a 1997 F250 standard cab long bed. For example, best bolt on exhaust, what size 3.5" or 4", best intake and possibly a programmer or chip... etc...
I'm looking to do upgrades that won't toast a stock transmission with approximately 215,000 miles.
I've looked at Banks Power and AFE to start with, but that's about it so far. Just doing homework right now before I purchase any upgrades.
Thanks, TJ
Old May 15, 2012 | 04:39 PM
fordpride's Avatar
fordpride
Mods in this order
6637 intake
3" Down pipe
get rid of the cat an muffler the stock 3.5 pipe is fine
Upgraded trans cooler
Gauges Boost, EGT and trans temp
Chip with custom tunes
A bone stock engine can destroy a stock trans. After doing mods it all depends on your right foot on how long the trans last
Old May 15, 2012 | 04:47 PM
1dieselman's Avatar
1dieselman
What Mike said plus if your trans is healthy now (do a pressure test on it) consider a torque converter and valve body upgrade, that should help your trans lead a longer happier life. You may also consider a 1.0 turbo housing on down the line.
Old May 15, 2012 | 05:18 PM
DarkStarMedia's Avatar
DarkStarMedia
Before you start doing upgrades I would highly recommend fixing any leaks or issues first... You know you have a few...
Check the valley for moisture and keep it clean. Check all your hoses and belt, etc... maintenance first...
Richard
Old May 15, 2012 | 10:28 PM
ReBilld's Avatar
ReBilld
Check the up pipes for leaks.
Old May 16, 2012 | 12:02 AM
oldbird1965's Avatar
oldbird1965
Intercooler if your going to pull anything. The list goes on.
Old May 16, 2012 | 01:08 AM
pjwoolw's Avatar
pjwoolw
Get your drivetrain, brakes and suspension in good order first. Might want to throw a new set of engine mounts and transmission mount in it. If your transmission is original save up some dough. Its only a matter of time before that needs to be addressed.
Old May 16, 2012 | 08:16 AM
redman84's Avatar
redman84
Fresh trans fluid and filter if it hasn't been done in a while too.
Old May 16, 2012 | 03:35 PM
t_jones792002
Thank you all!!! I really appreciate all of your info!
j250hd
Nov 8, 2011 02:54 PM
superrman77
Mar 24, 2011 08:34 AM
JamesHajek
39
Aug 24, 2010 06:22 AM
clouden
13
Sep 27, 2009 08:49 PM
jwe465
Nov 16, 2005 07:49 PM
