Major surgery
Old May 26, 2012 | 08:35 PM
  #31
tex25025's Avatar
tex25025
Originally Posted by SuperVossen
I have used it in all my other vehicles which were gas burners, so i have been cautious and haven't used it in my PS yet. I would probably use their full synthetic ATF though... I don't see why it would hurt it has better wear resistance than all the others am i right?
Ford's ATF is synthetic. The biggest thing is their tranny fluid is proven already. Why take a chance? It's cheap insurance in my mind.
As to your powermax with turbine diverter valve, your adding more moving parts to something that already has quite a bit of moving parts. It should work, but I can see if it were to go bad, it could go bad.
Old May 29, 2012 | 03:46 PM
  #32
SuperVossen's Avatar
SuperVossen
Where exactly are the middle cab bolts?
Old May 29, 2012 | 04:13 PM
  #33
SuperVossen
Nevermind guys.. I was looking RIGHT BEHIND the front seat because the writup said that the front seat had to be removed. I just cut a tiny slit in the carpet and Got her out !
Old May 29, 2012 | 07:13 PM
  #34
SuperVossen
Well I will stick with the Motorcraft then... And i am not getting a turbo for a little while so i have time to think on it more.. Any other turbo's that you think would be a better option?
Old May 29, 2012 | 08:19 PM
  #35
tex25025's Avatar
tex25025
I'm partial to my Non-VGT 64mm.
Old May 29, 2012 | 08:40 PM
  #36
SuperVossen
So, Here is what i have done so far... I have all the cab bolts out also but I didn't take pictures of every bolt hole. kind of redundant... All i have to do now is jack the cab up enough to get my homemade cradle under it to lift it. I will post pics of that also I can't wait to get this done!
Old May 30, 2012 | 11:46 AM
  #37
SuperVossen
Alright i have EVERYTHING disconnected.. i am nervous as hell about lifting the cab but nonetheless i have to get started.
By any chance, does anyone have an approximate or exact weight for the crew cab's actual cab? If i knew i wouldn't be quite so nervous. I am scared of the unknown!
Old May 31, 2012 | 06:05 AM
  #38
SuperVossen
Success!! and with no issues other than i forgot the ground strap behind the block but that was no biggie i found it before it even got tight
I have one question though, If a snap to connect fitting has a little play in it does it mean it's bad?
Old Jun 2, 2012 | 12:10 PM
  #39
SuperVossen
Down to the heads, i am surprised at how good everything looks inside, I had a couple valves that weren't sealing good. I lapped them and now they are seating properly, i will take pictures of me lapping them just for kicks and giggles. the pistons are mint with no pitting marks or excess wear. I am ecstatic! lol I am replacing the valve stem seals also on each valve even though the others were okay, cheap insurance.
Old Jun 12, 2012 | 01:52 PM
  #40
SuperVossen
Where do these go? I can't remember it's been a.week since I.took the cab off
Old Jun 12, 2012 | 02:09 PM
  #41
texans's Avatar
texans
Did you mean to post a pic, because I don't see one. Post a pic and I'm sure we can help you out.
Old Jun 13, 2012 | 07:34 AM
  #42
SuperVossen
I did, I see the picture in my post and the qoute?
Old Jun 13, 2012 | 12:27 PM
  #43
SuperVossen
I have four posts with pictures on them. Can ANYONE see.the.pictures?? Just in case there is something wrong withthe pics. I have two bushings with steel sleeves that I can't seem to.place on the truck. Every body mount looks complete already.
Old Jun 13, 2012 | 12:50 PM
  #44
SteveBricks's Avatar
SteveBricks
FTE Leadership Emeritus
FTE Emeritus
I can see them.
Scotty, the pics are hosted on photobucket, you might want to check and see if your browser has it blocked.
Old Jun 13, 2012 | 12:59 PM
  #45
texans's Avatar
texans
I can see them now. I'm not sure what thoes are though. You sure they came off the truck?
