missing helper spring brackets?
Old May 15, 2012 | 11:23 AM
akuhr93'f150's Avatar
akuhr93'f150
Question missing helper spring brackets?
So I have these helper springs on my f-150 but they are not supporting any weight and have just been sitting there. I want to hook them up correctly but I'm not sure how they were originally hooked up. Are those holes on my frame for a bracket for the springs or am I supposed to use a U bolt like what holds the springs onto the axle.
BTW before I got the truck the leaf spring shackles were replaced so could it be that if there was helper spring shackles they were removed and not replaced?
Old May 15, 2012 | 01:09 PM
White 97 xlt's Avatar
White 97 xlt
I don't think it missing brackets, but more like missing U-bolts.. Here is a pic of what it looks like you have... I didn't look up the exact application but posted this pic since it is clear and shows what it should look like...
Here is the site the pic came from... Hellwig - Load and Sway Control Products
I don't know if they sell parts separately or not but you might check them ans see...
Old May 15, 2012 | 11:07 PM
akuhr93'f150
thanks a lot. Does every truck of this generation have holes predrilled in their frame there then and what are they for? And if I bought new U joints and idea how tight they should be torqued down?
Old May 16, 2012 | 08:00 AM
Conanski's Avatar
Conanski
yes
And what are they for?
Who knows
You mean U-bolts, U-joints go in the driveshaft.
Any idea how tight they should be torqued down?
Not very tight, the more you crank down on them the more the rear of the truck will lift, so if you just want the extra load capacity then just tighten the bolts enough to make them snug and not rattle around too much.
Old May 16, 2012 | 08:56 AM
akuhr93'f150
Cool thanks a lot! And yeah, U-bolts. It was pretty late her in Milwaukee when I wrote that, my mistake.
Old May 16, 2012 | 11:37 AM
big vann's Avatar
big vann
Here is a factory set-up.I'm told the truck was called a Trailer Special.It's an '88 F250 4x4 reg cab.The brackets are just above the springs.
Old May 16, 2012 | 01:00 PM
Conanski's Avatar
Conanski
That was only available on HD trucks.. not the F150.
Old May 16, 2012 | 02:17 PM
big vann's Avatar
big vann
Oh.Hahaha.Hence Trailer special and 8600lb GVW.Mostly in response to OP question re;holes in the frame.Did they use the same frame for f150 and f250?(excluding suspension).
Old May 16, 2012 | 03:37 PM
Conanski's Avatar
Conanski
The F150 and F250 light duty(under 8500lb GVWR) frames are similar though I believe the F250 version is heavier(thicker) steel, but the HD truck frames are much bigger in every dimension and heavier gauge as well.
E T
Aug 17, 2018 02:47 PM
Restlesswildman
Aug 14, 2014 09:21 PM
Plain Jane
Dec 16, 2011 09:42 AM
Anafiel
Dec 1, 2010 04:06 AM
David85
Jul 5, 2009 07:24 PM
