another standpipe ?
Old May 15, 2012 | 05:32 AM
jsimon724's Avatar
jsimon724
another standpipe ?
Quick background on truck. Bought an 05 6.0 at auction for work, 205k on the clock, actually in pretty good shape. Was running rough on cold starts, found out FICM voltage was low, pulled it and fixed, truck started and ran great. Week or two goes by, started to notice hard starts when warm. Checked ICP pressure (using AE, btw), found it low at startup. Got the engine torn down right now, we're doing STC, rebuilt oil cooler and BPD EGR cooler while we're there, also standpipes and dummy plugs.
Question is the new standpipes are 7 or 8" long and what came out of the oil rail is only about 3"? Bottom part of the new piece looks almost like an extension tube of some sort, but shouldn't it have come out when we backed out the old standpipe? What am I missing here?
Thanks
Old May 15, 2012 | 06:06 AM
ul37's Avatar
ul37
stand pipes are 2 peices.you have to remove lower half from engine.they dont always stay together.if it came a part you will have to remove oil rail(manifold) to remove lower half.unless you have a tool to get to it.
Joe
Old May 15, 2012 | 06:36 AM
jsimon724's Avatar
jsimon724
is there a tool available from the dealer to remove it easily? or is it not a big deal to pull the oil rails?
Old May 15, 2012 | 06:59 AM
ul37's Avatar
ul37
if it was me i'd pull the rails.your already there.just looked the tool we have wont reach thru the rail to the pipe.
Old May 15, 2012 | 07:07 AM
jimmyv13's Avatar
jimmyv13
Pull the rails, it's not bad. My passenger pipe came out in 2 pieces, a long needle nosed pair of vice grips was the tool of choice.
Old May 15, 2012 | 08:02 AM
jsimon724's Avatar
jsimon724
Thanks, guys
So far, so good. Passenger lower rear 2 bolts near condenser box are a pain. Finally got em with a T30 bit and a 1/4" box wrench. Driver's side to go, and then start putting it back together. Keeping my fingers crossed.
hwybee22
Feb 6, 2018 07:45 PM
cleatus12r
101
Mar 12, 2015 10:47 PM
UGA33
Nov 5, 2014 06:08 PM
High Binder
Oct 16, 2012 11:29 AM
redman84
Apr 23, 2012 08:52 PM
