1950 f1 draglink diagram
With the C-clamps stopping the pitman arm the steering wheel still has a bit of play, probably just under 1 hour, so a 1/18 of a full rotation of the steering wheel.
Thanks
That is acceptable play. Is the engine out? If so, it's super easy to pull the box now, I would do so. The Workshop Manual has the criteria for setting worm endplay/preload, very simple to do if the gears are in good shape. If the sector shaft bushings are worn, easier to replace now. Worst case, you take it apart, put it right back together, hopefully without leaks.
Mine's leakage turned out to be from the adjustment bolt for the sector shaft. There's no "seal", so once it was set, I goobered it with RTV, put the cap on and let it sit a day or two before adding oil.
Believe it or not, 90wt dripping on the front spring is bad for it, it's worth chasing!
Leichardti
Electrical Systems/Wiring
16
06-29-2015 10:24 AM
mando jake
01-12-2009 04:59 PM
1949f1
04-03-2007 03:56 AM
