Bad ignition module?
Old May 14, 2012 | 02:55 PM
bamaf150's Avatar
bamaf150
My truck has stalled on me 3 times recently and once with the old engine a long time ago, same module though. Symptoms are it starts wanting to die, like its running out of gas and I'll come to a stop and it will either smooth out and run fine or die but I can restart almost immediatley and it will run fine. I had a '79 years ago that had a bad module but it would just die and I would have to wait 5-10 mins for it to cool before it would restart.
Old May 14, 2012 | 06:55 PM
fmc400's Avatar
fmc400
MSEE
It's possible, but it's less common for the engine to stumble prior to shutting off - usually it cuts out completely. If it's acting like it's running out of gas, then maybe it's actually running out of gas (carburetor, float issue) or vacuum problem.
Old May 14, 2012 | 07:08 PM
bamaf150's Avatar
bamaf150
Thats how my '79 acted way back in '84, it would die just as if you had shut the key off. My '76 stumbles, acts like its running out of fuel then runs great. Its got a Holley 4160 IIRC, been awhile but gas was right at the peep hole last time I checked.
Old May 14, 2012 | 08:31 PM
ohmyf150's Avatar
ohmyf150
This sounds similar to what my truck was doing. It ended up being the magnetic pickup in the distributor. It would test fine when cold but when the truck was warm, it would start cutting out with similar symptoms to what you described. Replaced it and it has been great ever since!
Old May 15, 2012 | 03:51 AM
bamaf150's Avatar
bamaf150
Thanks, I will look into that as well Ohmyf150
Old May 15, 2012 | 06:49 AM
ChiefM's Avatar
ChiefM
Could be a bad coil too, I have seen them short out when hot.
ENCLOSURES
19
Dec 19, 2010 10:29 PM
partsman01
Jan 1, 2009 11:32 AM
remmers
Aerostar
70
Apr 14, 2005 09:38 PM
lakahahahman
1983 - 2012 Ranger & B-Series
Feb 17, 2004 10:15 PM
Avanti
Bronco II
Oct 9, 2001 06:25 AM
