Stupid distributor clamp question!?
Old May 14, 2012 | 12:10 PM
seawulff's Avatar
seawulff
I have a '56 F100 with a "57 312 stuffed in the engine compartment. The distributor needs rebuilding but I can't reach the bolt at the base of the distributor to loosen it. Short of hiring Elastic man or removing the engine does anyone have any suggestions on how to loosen that bolt? I can't seem to get at it from above, do I reach around from underneath or is that absurd.
Old May 14, 2012 | 12:48 PM
jaye's Avatar
jaye
There are distributor bolt wrenches that should take that right out,they come in sizes 1/2 & 9/16 that I know of; I got mine from Advanced auto parts.
Old May 14, 2012 | 01:28 PM
raytasch's Avatar
raytasch
Believe Nothing
I can get to mine, 272 CID, same external size, from the driver side. A short half inch open or box wrench works well.
Old May 14, 2012 | 01:31 PM
seawulff's Avatar
seawulff
There is a lot of accelerator linkage stuff attached to the carb on that side, I might need to take some of that off to get my hand in there but that side gives me the best visual. Thanks.
Old May 14, 2012 | 02:10 PM
seawulff's Avatar
seawulff
I found this online, does this look like it would work?
VIM Tools (Durston Mfg.) , V106 Distributor Wrench 12-Pt. 1/2 In Ford 1956-65 V8
Old May 22, 2012 | 11:31 AM
seawulff's Avatar
seawulff
Thanks for the information, I got a distributor wrench designed for my engine for $14 and it works perfectly. Now all I need to do is get the 60 years of grit cleaned off so I can pull the thing out!
warren561
Sep 9, 2014 08:42 PM
bowling1
Aug 24, 2014 07:37 AM
bcsbadboys
Nov 20, 2006 01:57 PM
faroffthetrack
Apr 23, 2004 11:21 PM
garageinc2001
1983 - 2012 Ranger & B-Series
Jul 25, 2003 10:54 AM
