'92 4.9 Rough Idle - Help
Old Oct 6, 2002 | 03:07 PM
JW 4x4's Avatar
JW 4x4
After my truck warms up, and I shut it off and restart it, sometimes it will idle very rough, almost as if a plug wire was off. However, if I shut it off and restart it again, the idle returns to normal. What does this indicate? Thanks for any help!
Old Oct 7, 2002 | 02:57 PM
Squiggy's Avatar
Squiggy
Umm check the Intake gasket and egr valve... Inside there is a valve that controls the amount of exaust gas that enters the engine for warm up... If it is jammed open like I suspect then it would have a funky Idle and if you shut it off it makes the vacumm go away in turn closing it when you start it again.... check er out
Old Oct 7, 2002 | 04:17 PM
SPROCKET's Avatar
SPROCKET
jimwink
Sep 30, 2011 05:11 PM
hornsurgeon
1997 - 2003 F150
Dec 19, 2010 12:17 AM
89Wrangler
Feb 7, 2006 05:51 AM
deklyend
Jul 1, 2004 06:30 PM
brown 4x4
Feb 27, 2001 03:47 PM
