Sponsored by: Real Truck
Got a brake problem
Old May 13, 2012 | 07:11 PM
BrentEllisD's Avatar
BrentEllisD
Got a brake problem
I keep blowing the seals on my right rear caliper. I get a new one and it leaks. I thought it was parts related but I have changed it out 5 times now and I am at a loss. I was wondering if anyone knows if the brake control module on a 2004 f-350 superduty could cause too much pressure to go to just one caliper? And if not what could?
Old May 13, 2012 | 11:27 PM
99f350sd's Avatar
99f350sd
If the rotor is good and the pads are good its the caliper..If the rotor and pads are worn too much maybe I could see a problem but not really..If you had too much pressure the tire would lock easily.. Get a different brand caliper like wagner...Actually never heard of such a thing. Been wrenching before disc brakes were....
Dick
Old May 14, 2012 | 08:12 AM
BrentEllisD
Dick
Okay well I have used this caliper on the left rear before and had no issues. The pads are brand new and the rotor is new as of last year. I am not asking if the hardware or parts that I can plainly see are good or bad or not. I am asking if in the brake system if there is a component that could cause a difference in brake pressure application from one rotor to the other on a 2004 f-350.
Old May 14, 2012 | 08:22 AM
99f350sd's Avatar
99f350sd
I gave you my best answer..Nothing I know of can cause a caliper piston boot to blow out if all the mechanical is AOK..excess pressure will just lock wheel..IMO.
Dick
Old May 14, 2012 | 08:51 AM
Christof13T's Avatar
Christof13T
maybe a warped rotor causing extra stress on the seal? wheel bearing? if you grab your wheel can you wiggle it on the bearing and feel ANY play?
is there such a thing as bad fluid? or the wrong type? something eating the seals maybe?
hope you get it figured out... and let us know eh?
xtof
Old May 14, 2012 | 09:03 AM
fmtrvt's Avatar
fmtrvt
Since both rear calipers are fed from the same union connected to the single drop line frame to axle, there is nothing from the application system that is over pressurizing one wheel end.
Five calipers that have leaked? Where are you getting these calipers from? And what do you consider a leak? Is it possible that your supplier is using excessive assembly lube which has bled out from the dust boot rather then brake fluid loss?
Old May 14, 2012 | 07:24 PM
BrentEllisD
I have gotten all the calipers from O'Reilly's auto parts. They only have re-manufactured brakes. No new brakes in town. Needless to say I won't be buying my parts there anymore. What I consider a leak is brake fluid running down the inside of my tire and leaving puddles on the ground.
Old May 14, 2012 | 07:27 PM
99f350sd's Avatar
99f350sd
Sounds like a bad bunch of calipers.
Old May 14, 2012 | 07:34 PM
Christof13T
yeah i would tend to agree that puddles of fluid on the ground constitute a legitimate leak.
i cant believe that a part that passes all its inspections at the manufacturer, and that many of them fail consecutively. cant speak for orieleys because i dont get my parts there... i like napa... they havent let me down yet.
is it a possibility that maybe the parts were not direct replacements for your truck? like a system glitch ir an input error that put them in the wrong place in the system... otherwise there is a serious manufacturing issue going on. would be interested to know if anything comes of this... what is the orieley part number for what they sold you?
Old May 14, 2012 | 08:40 PM
dharmabum's Avatar
dharmabum
Are you sure the leak is coming from the caliper piston seal and not the crush washers on the banjo bolts? These should be replaced when replacing calipers but it's sometimes overlooked and they are reused.
If it is the caliper piston seal as said before the pressure would be balanced between the two sides as they are fed from the one line. The only other thing I could think of is a possible stuck caliper or line obstruction on the left side which would cause the right caliper to get slightly more pressure but you would feel the truck pull right when braking and even still it shouldn't be blowing seals.
Old May 14, 2012 | 09:07 PM
fmtrvt's Avatar
fmtrvt
Yeah that’s a pretty good leak.
>>>> I cant believe that a part that passes all its inspections at the manufacture ….
You have an optimistic view of what happens in the aftermarket.
>>>> Is it a possibility that maybe the parts were not direct replacements for your truck?
Nothing else bolts up.
That is an excellent point. If you used an aftermarket copper washer often they are thin and don’t have the same crush. If you reused the original washers, they become work hardened during the initial use and will not seal correctly. If the copper washers have to be reused then they need to be heated cherry red and allowed to slowly air cool to soften them for reuse.
The best way to check if the leak is coming from the banjo connection is spray the area with alcohol to wash off the glycol and dry quickly. With the engine running, have someone press the brake hard while you watch for fluid escape.
Old May 18, 2012 | 07:51 PM
BrentEllisD
Yes I replace the washers, and yes I am sure that it is coming from the seal. I guess it must be just a bad batch of parts. I just let the guys at the parts store convince me that it was the truck and not their parts. I am just blown away by the idea that so many consecutive parts could be bad. Thanks for the help everyone I consider this case closed... unless I get a bad brake from Napa then I will be back.
Old May 18, 2012 | 09:07 PM
04Terminator's Avatar
04Terminator
I'm just spit balling here but could it be the wheel seal leaking ? Have you seen it coming from the caliper dierectly? A wheel seal will sling oil everywhere. Try pulling the caliper off with the line still hooked up and with someone to help you. put a small piece of wood in the caliper so the pistons won't fly out clean it up real well and have them push on the pedal while watching the caliper. Just an idea.
Jbartleyw
2009 - 2014 F150
May 12, 2018 03:09 PM
magnet1
2004 - 2008 F150
Aug 25, 2009 01:06 AM
bekko
Mar 16, 2008 12:03 PM
hflu
Aug 30, 2004 04:07 PM
Muleskinner
Oct 21, 2002 07:05 AM
