1999 ''ringing''
Old May 13, 2012 | 05:46 PM
ford dually's Avatar
ford dually
1999 ''ringing''
Hi all, I have a 1999 f350 7.3l with 82600 orig. miles on it and it sounds like there is a ''ringing'' inside my engine. Infact I had a friend yesterday say that it sounded like a squealing pulley. I have another friend that has a 2000 f250 with a 7.3l in it and he says that all the 1999's had this ''ringing'' and that it is normal. Is this true have any of you guys herd of this or is it a problem? I remember reading that the injectors are different in a 1999, is this the reason? What do you guys think?
Old May 13, 2012 | 06:05 PM
nlemerise's Avatar
nlemerise
I have a 99 and never heard anything I would describe as a "ringing" from the engine.
Old May 13, 2012 | 06:18 PM
smithrock's Avatar
smithrock
I have an '02 and I get "ringing" from time to time, but only when towing. And I think it's coming from the tranny
Old May 13, 2012 | 06:53 PM
snakedoc's Avatar
snakedoc
how about a bad pulley or bad belt
Old May 13, 2012 | 07:21 PM
ford dually
Thanks for the speedy reply guys, I've had my tranny checked about 4 different times and the fluid is clean as could be, and I dont tow with it, so im sure its not that. I replaced the belt myself last summer with a genuine ford belt from dealer. I guess i should've spun the pulleys to see if any one of them squeaked but would'nt a bad pulley be pretty evident?
Old May 13, 2012 | 08:43 PM
Krazymaan's Avatar
Krazymaan
if its a high pitch ringing, it could be the impeller on your turbo. Shove your camera in there and take a photo and examine it. Or maybe your turbo bearing is going and the impeller is touching the sidewall ever so slightly under load. That is very possible.
Old May 13, 2012 | 08:57 PM
bigb56's Avatar
bigb56
I've had that high pitched ringing for a while, but I may have found the cause. I'll be replacing the turbo as soon as I get a new one.
Old May 13, 2012 | 09:14 PM
bcaughhorn's Avatar
bcaughhorn
I don't believe its because its a 99. My 99 never made a ringing.
Supercab
Apr 23, 2008 01:07 PM
Spirit615
Jul 31, 2005 05:06 PM
cerebixed
1983 - 2012 Ranger & B-Series
Mar 17, 2005 06:16 PM
RandyK
Oct 22, 2004 07:35 PM
plaster93
1997 - 2003 F150
Aug 28, 2004 07:24 PM
