Sponsored by: Real Truck
Serpentine belt
Old Oct 22, 2004 | 10:21 AM
RandyK's Avatar
RandyK
Serpentine belt
I currently own a 99 F250 4X4. I previously owned an 88 F150 Custom. With both trucks I have had trouble with the belt squealing whenever it is damp outside. In the summer months it's fine. I have replaced the serpetine belt 2X already on the 99. It is fine for a while then it starts to squeal again. I have shot WD40 on it and this only stops it temporarily. I was wondering if it is the tensioner pulley or something else. Thanks for any feedback.
Old Oct 22, 2004 | 06:28 PM
BigRyanKP's Avatar
BigRyanKP
umm WD-40 isn’t exactly a good idea, you want the belt to be sticky not slide off the crank pulley slippery use a belt cleaner or brake clean can work too but all these are temp fixes. My 99 v10's belt needs replaced about every 15k miles from glazing up.
Old Oct 22, 2004 | 06:43 PM
99f350sd's Avatar
99f350sd
Try a different brand of belt...they are different qualities. also check the idler pulley bearings they go bad..
Old Oct 22, 2004 | 07:35 PM
1ruralmailman's Avatar
1ruralmailman
how many miles aer on this? if it is much over 50000 miles there is a good chance the tensioner is used up. i do agree however it could be the belts, i have had no luck with napa belts staying quiet at all.
69ford99
2004 - 2008 F150
Oct 16, 2011 01:33 PM
f150v602
2004 - 2008 F150
Apr 18, 2008 07:43 AM
pdqtimetrialer
Nov 16, 2007 10:53 AM
richard k
May 27, 2001 07:15 PM
