Idle problems
Old May 13, 2012 | 05:25 PM
wiyakpa's Avatar
wiyakpa
Idle problems
Hey all I have a 95 f250 4x4 obs 7.3l that has a ruff idle and a shimmy when it goes into overdrive (45mph) when it gets above 50 or below 40 it seems to run fine . the truck has 315,000 miles on it. I have had it to ford and a diesel shop the best I got from them was to replace the motor in the last yr I have replaced the uvch ,glow plugs and controller. Have just replaced the EBP Sensor. I get 17mpg in town and 20 on the hwy empty just cant believe it would be the engine. Any idea’s ???
Old May 13, 2012 | 07:19 PM
427 fordman's Avatar
427 fordman
Have you had any work on the injectors? 300k they are more than likely due if you haven't. Does it smoke at all?
welcome to fte.
Old May 13, 2012 | 09:05 PM
wiyakpa's Avatar
wiyakpa
welcome to fte.
no I have not and no smoke other then black, when it was in the shop they said the injectors tested fine
Old May 13, 2012 | 09:39 PM
redman84's Avatar
redman84
Could a worn out HPOP cause that? How about bad ICP or MAP?
Old May 13, 2012 | 09:44 PM
wiyakpa's Avatar
wiyakpa
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> no codes no check engine light
Old May 13, 2012 | 09:54 PM
fordpride's Avatar
fordpride
Have you ever done injector o rings?
You won't get any code for a weak HPOP
Old May 13, 2012 | 10:01 PM
wiyakpa's Avatar
wiyakpa
no I have not is there a way to test for a weak hpop
Old May 13, 2012 | 10:04 PM
fordpride's Avatar
fordpride
Yea would need a scan tool that can see live data or build a 5000psi gauge setup to hook to the head so you can see what the pressure is doing
Old May 13, 2012 | 10:16 PM
wiyakpa's Avatar
wiyakpa
hmm guess ill be building a gauge had I not spent all the fees to have it checked out I could have bought a good scanner lol will let you know what I find
Old May 14, 2012 | 05:32 AM
427 fordman
A couple tests to give us an idea if your injector orings are ok.
When is the last time you changed the fuel filter? How did it look?
If you leave it in neutral and free rev it to 3k, does it stumble bad?
Old May 14, 2012 | 10:35 AM
wiyakpa's Avatar
wiyakpa
just changed the fuel filter last week looked like normal will try the rev test this afternoon
ok from about 1300 up smoothness
Sweater61
Dec 24, 2014 11:47 PM
dentsideranger
13
Apr 18, 2012 07:25 PM
4inchlovin
Dec 8, 2007 10:39 AM
funzjb1
May 23, 2007 02:02 PM
gabyski
Jun 28, 2005 05:23 PM
