thermostat?
Old May 13, 2012 | 11:33 AM
vfelix702's Avatar
vfelix702
thermostat?
gents i bought a new thermostat for my lead sled this morning and it came with a seal around the flange and a seal on the body of the thermostat like in this picture do i disguard these seals ? its the stat on the left murray..... List: Thermostats - 1990 Ford F-250 | O'Reilly Auto Parts
Old May 13, 2012 | 12:37 PM
akamacgyver's Avatar
akamacgyver
Clueless spectator!
Felix,
Everyone on this site reccommends to use only the Motorcraft or International OEM replacement stat. There are some threads pertaining to why on here. I would do some reading up on it first. IIRC my Motorcraft stat had only one gasket.
Good luck,
Mac.
Old May 13, 2012 | 12:39 PM
vfelix702's Avatar
vfelix702
Mack was the gasket around the body or flange? Everything I have read says remove the flange gaskest but I wanted to check with somone else..
Old May 13, 2012 | 02:06 PM
whalebus2112's Avatar
whalebus2112
Use a motorcraft. They pass more coolant
Old May 13, 2012 | 09:46 PM
IDIDieselJohn's Avatar
IDIDieselJohn
The ONLY good aftermarket thermostat for these is the Stant thermostat. They are made exactly like the Ford or IH one. DO NOT USE any other brand!
Old May 14, 2012 | 09:11 AM
fuzzy1626's Avatar
fuzzy1626
Heard the same since I've been here.
Old May 14, 2012 | 11:09 AM
akamacgyver
Clueless spectator!
Code:
Felix, the gasket I got with my motorcraft t-stat was a flange gasket IIRC but it was some time ago.
Old May 14, 2012 | 12:07 PM
whalebus2112
I just did mine with a motorcraft one. the stat sits in a little gooved out part and it comes with a cardbord gasket that seals the 2 T stat housing together
KD90
Nov 24, 2017 12:41 AM
bleudia
Aerostar
16
Nov 19, 2014 03:32 PM
adamkat22
Jan 9, 2013 09:50 PM
alanc77
17
Jan 30, 2011 10:11 AM
dvskate
97
Feb 16, 2010 09:54 AM
