electric lock issues
Old May 12, 2012 | 10:39 PM
jfink72's Avatar
jfink72
I have a 2006 f150 fx4 and the electric locks keep locking and unlocking. It is sitting in the drive now I can here the actuator working. Even when I click the lock or unlock button it continues to cycle. anyone heard of this before?
Old May 13, 2012 | 08:39 AM
08FX4F150's Avatar
08FX4F150
lock problem
look in your owners manual--if you don't have one i can dig mine up..try performing the disable auto locking procedure it describes.. then you can always reactivate later....
Old May 13, 2012 | 11:47 AM
Papa Tiger's Avatar
Papa Tiger
Look to a low defective voltage battery. The system goes B-zerk with low voltage. Usually a new battery ok's things if Alternator is doing 14 volts.
Old May 14, 2012 | 10:04 AM
jfink72's Avatar
jfink72
I appreciate all of the suggestions. I turned off the auto lock feature. IT was a challenge to get the sequence down because the locks keep locking and unlocking while I was going through the steps. Once I got it completed it did not stop.
I will check the battery. I replaced the battery in Aug of last year with an Optima red top so I hope it's not going bad already.
It's funny how it does it starts when I lock or unlock it. Then after a period of time (never the same amount) it will stop. I parked it in the drive this morning and I could hear it working away. I walked out an hour later and thought it had stopped. Instead of doing it one right after the other it was unlocking about every 3 min. It's also weird that once I getack in the vehicle if I try to unlock the passenger door I have to do it with the door handle as the power locks won't work.
I figure unless I can figure out what it is the door locks will just stop working alltogether before long.
Old May 19, 2012 | 12:02 PM
jfink72's Avatar
jfink72
well it did stop. the doors no now longer unlock via the switch on the door panel. I have done some research and tore into it. I believe it to be the drivers side door switch that was bad. Soon to ind out for sure.
deano2
1997 - 2003 F150
Jun 11, 2010 10:51 PM
shiloh66
Jan 30, 2008 10:13 PM
Cook421
1997 - 2003 F150
May 7, 2007 11:01 PM
4x4triton
Electrical Systems/Wiring
May 26, 2005 09:08 PM
1ford1
1997 - 2003 F150
Mar 29, 2004 08:55 PM
