power door locks
Old May 23, 2005 | 11:52 PM
4x4triton's Avatar
4x4triton
Unhappy power door locks
i have a 2001 f-150 lariat 4x4 and the door locks are acting strange. It almost acts like if i have a low battery but everything else works fine, when i hit the lock button the doors lock but when i hit the unlock button they are a little weaker to unlock, then if i hit the lock button again they will lock but even slower then unlock again even slower, if i do this (lock then unlock) several times it gets weaker and weaker until it just stops working, then i can let it sit a little while and it starts working again for a little while, but the power windows and lights work fine, seems like a low battery would do this to everything.
please help
thanks in advance,
triton
Old May 24, 2005 | 08:47 PM
Franklin2's Avatar
Franklin2
I don't know if Ford still uses them, but the older door locks were actually a little motor and ran back and forth. There may be something wrong with the lock mechanisms themselves.
The only thing I would try is reading the voltage going to the lock actuator while you are flipping them on and off, to verify they are not starving for voltage.
Old May 25, 2005 | 09:45 AM
cangim's Avatar
cangim
I know on the Superduty body styles, the 99 to 01 suffered from some pretty poor lock actuators, I have replaced a coule of mine already, they where doing the exact thing you are describing. If everything else checks out okay, you will probably need a new lock mechanism. When I got mine it was around 50 bucks.
Old May 26, 2005 | 09:08 PM
4x4triton's Avatar
4x4triton
Thumbs up
Thanks fellas, ill try that
triton
