What's up with this?
May 12, 2012 | 02:10 PM
At 2700 rp m's it starts blowing smoke out the tailpipe like crazy and it's raw fuel
May 12, 2012 | 04:27 PM
You Have a BAD Injector
Sounds like its stuck on
scan for code see if that will give a balance code for certain cylinder
Might even need to try Ballon test if no Codes
be Very Careful here as an injector dumping fuel into cylinder can cause Catastropic failure Fast
May 12, 2012 | 05:59 PM
only does this when free reving the motor in park doesnt smoke while driving.
May 12, 2012 | 06:01 PM
i did the crank with fuel bowl open and no bubbles have a gauge on it and it is 60 psi fuel pressure
May 12, 2012 | 06:47 PM
I assume Ficm Power Side OK 48Volts
any codes any code reader or??
How Many miles
May 12, 2012 | 07:54 PM
Can you scan the exhaust manifolds w/ an IR temperature gun to see if any cylinder looks way different than the rest?
May 12, 2012 | 08:23 PM
when u "free rev" in park, and go to a high-enough rpm, u will be lifting the heads slightly. our 6.0 has so much torque and HP behind the wheel. i'm not surprised if tat happens for u. i might consider new headgaskets and ARP studs. tat might help to eliminate any possibility of fuel or anything else seeping back and forth, if u catch my drift. lol.
if i'm wrong about this assumption, please dont shoot down the snuggyworm. after all, i'm cuddly and cute. lmao!
May 13, 2012 | 12:25 AM
ficm is 48-48.5volts no codes on the SG2
Ill try the temp gun tomorrow i dont think it would be headgaskets never had an over heating issue.
UGA33
Aug 23, 2016 09:44 AM
jedlicka87
Jan 30, 2013 08:54 PM
JPdiesel
Mar 2, 2012 01:51 PM
seth1
Jan 31, 2012 06:24 PM
garsm
26
Jun 28, 2011 07:59 PM
