96 F250 fuel flow problems
Old May 10, 2012 | 03:44 PM
kevin g's Avatar
kevin g
I am having trouble with my 96 F250. It will start and run (at low RPMs) for a few minutes and then run rough and then finally stop running. If I turn on the ignition, I will hear the fuel pump for a second or two then it will turn off. I think this is normal. If I do this several times, the truck will run at higher RPMs once started but the above results will eventually reappear after a couple of minutes. I have replaced the fuel filter, and I replaced the fuel pump last year. Do i need to bleed the fuel system since replacing the filter or is something else causing my problems? Any help would be greatly appreciated.
wetneck
1978 - 1996 Big Bronco
15
Aug 26, 2010 05:00 PM
clwoodall_76
Dec 4, 2009 10:11 AM
xgatorx1976
Nov 20, 2009 06:45 AM
john1
Sep 27, 2004 11:23 AM
