carb tuning, fast idle
Old May 10, 2012 | 08:35 AM
siloketh's Avatar
siloketh
Recently my truck started idling a bit higher than normal over the weekend so I didn't think much about until I noticed a slight decrese in mileage. I dont know what caused the idle to change but its getting on my nerves. The only way i can describe the rpm change is using v8 idle range which 500rpm is normal but I would compare it to 1200rpm at idle on my truck.
My truck is equipped with a single barrel wiend carb electric choke. Is there something wrong in the electronics or do I need to adjust the carb to idle lower when warm? By the way, I dont know how to adjust a carb and all my buddies are fuel-injected...figured I should add that bit in there.
I've had this truck since december and never had this hiccup before. Any help is greatly appreciated. Thanks once again guys
Old May 10, 2012 | 09:37 AM
Harte3's Avatar
Harte3
Check for vacuum leaks first. If there is one or more you will end up chasing your tail trying to adjust the carb.
Old May 10, 2012 | 10:18 AM
1986F150six's Avatar
1986F150six
As Hart3 said, check for vacuum leaks. The 1 barrel carburetor is held down by two bolts which tend to vibrate loose. See if you can move the carburetor or air cleaner assembly back and forth. If it moves, they are loose. Take a 1/2" wrench and gently snug them. Check all of the screws which hold the top of the carburetor. There are 4 screws on the bottom of the carburetor, but the carburetor has to be removed to access these.
This engine really acts up when vacuum leaks are present, so check all vacuum hoses and ports. There are ports [often times capped off] on the intake manifold tree and on the firewall [passenger side]. These caps can get brittle and crack or fall off. Some of the vacuum lines are originally plastic and get old and crack. They can be replaced with rubber vacuum hose [do one at a time so they do not get crossed up].
Check the throttle shaft for excessive play and try disconnecting the throttle cable to see if the cable is binding.
Old May 10, 2012 | 10:31 AM
siloketh's Avatar
siloketh
Thanks once again ya'll. I will check for the vac leaks and loosened bolts and go from there
Old May 10, 2012 | 11:19 AM
arctic y block's Avatar
arctic y block
1986F150six has said it all. And said it very well. Vacuum leak and or throttle plate bore worn are where to look first.
When this is eliminated come on back and we can help you adjust it if need be.
Old May 14, 2012 | 10:58 AM
siloketh's Avatar
siloketh
The bolts came loose over time. Snugged them down to spec in my haynes manual. The idle improved but was still a little high, so i adjusted the idle just a touch & now she purrs like a kitten sittin at the red light thanks everyone once again for your help/advice
Mutilator712
16
Oct 16, 2016 08:46 PM
silar
Feb 22, 2015 07:02 PM
antunez13
Nov 13, 2007 02:05 PM
BuffDaddy
Jun 25, 2006 11:06 AM
sfc11b
Jul 25, 2004 06:41 PM
