oil filter relocation in 7.3
Old May 11, 2012 | 08:34 AM
mueckster's Avatar
mueckster
Originally Posted by miller_feed
I make sure I can turn the filter before I jab a hole in the bottom of it to drain the oil.
Words of wisdom from one of our senior members.
Old May 11, 2012 | 08:47 AM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Wisdom????????????????
Senior is right, but Wisdom, you know me better then that Roland.
Old May 11, 2012 | 09:49 AM
UcaN's Avatar
UcaN
First thing i do is put on a pair of latex gloves on. Then loosen filter. Then poke hole on bottom of filter. Then turn fumoto valve open.... wait a few minutes, then finally get a plastic grocery bag wrap it on filter and remove it. Not a single drop of oil makes its way to my floor or on me.
Old May 11, 2012 | 10:10 AM
CSIPSD's Avatar
CSIPSD
I use what ever I jab into the filter to turn it off... But thats just me...
Old May 11, 2012 | 10:25 AM
mtdigger's Avatar
mtdigger
Dang...I must be doing this wrong, I can loosen the filter by hand after a good wipe...I only tighten it by hand, granted...ill use both hands and crank it down...but they always come loose. Loosen....then poke the hole. No wrench needed
Old May 11, 2012 | 10:32 AM
miller_feed
I've only had one filter that would loosen up and start leaking. I tightened it up a couple times, but finally changed it out with a new filter and was good to go.
It don't much matter how you do the filter, as long as you get the old off and the new on without a leak, is good.
Old May 11, 2012 | 01:32 PM
bfife's Avatar
bfife
still plays with trucks
I always poke a hole in mine to drain it. then once its loose, I slip a 2 gal zip loc bag around it and spin it off. this puts the filter directly into the bag and no drips. this and a Fumoto valve makes for one clean oil change.
Barney
Old May 11, 2012 | 02:15 PM
kccatpower's Avatar
kccatpower
i knew i was doing something wrong, slide the five gallon bucket under the filter give it a good spin and try to get out of the way when it comes off and hits the bottom of the bucket.
Old Oct 5, 2012 | 01:23 AM
cherokeewheeler's Avatar
cherokeewheeler
I did the same thang about a week ago but it got hung up side down on the drive line and drain out all over me. yeah it SUCKED lol
Old Oct 5, 2012 | 07:36 AM
Punisher29073's Avatar
Punisher29073
I take a sawzall and cut an Z in the bottom of the filter like Zorro would do. Then put a wrench on the drain plug and have my little girl hold it while i spin the truck around it. All while wearing a mask and one one of my wifes poofy shirts and carrying a broom I dressed up like a horse.
I think I will try the awl thing next time.
Ryan
FordF350Superduty
Oil & Lubrication
Sep 10, 2022 06:51 PM
Medic 66
Jun 8, 2006 11:14 PM
kitsapcountychopper
Mar 8, 2004 06:40 AM
fordiesel69
Jan 28, 2001 08:31 PM
