early 99 7.3 difficulty starting
Old Apr 14, 2011 | 03:36 PM
Napewastewin's Avatar
Napewastewin
DTC code reported as P1670 - Electronic feedback signal not detected. What is this, where do I look, what needs to be changed?
Old Apr 14, 2011 | 04:03 PM
clintbonnie's Avatar
clintbonnie
Here is some more info on p1670.. did a search :
FJ1 DIAGNOSTIC TROUBLE CODE (DTC) P1670 and P1668
DTC P1668 and P1670 indicates that a communication error has occurred between the PCM and the IDM.
Possible causes:
Open fuse
IDM relay
Open or shorted IDM enable circuit
Open/short in EF circuit
Open/short in FDCS circuit
IDM powering circuits
PCM
Check for other codes.
Key on, engine off.
Perform KOEO On-Demand Self Test and retrieve Continuous DTCs.
Old Apr 14, 2011 | 04:05 PM
tdpower's Avatar
tdpower
I think low batteries can cause that code so I would get your batteries load tested.
Old Apr 14, 2011 | 05:34 PM
Napewastewin
Thanks for the quick response. I talked to my guy in service also and I will get the load test done tomorrow. Start with the simple and work my way into the deep.
sparkkky
2004 - 2008 F150
Aug 21, 2011 03:02 PM
SuperSnake
Maryland Chapter
68
Jul 9, 2008 12:17 PM
JByrd1173
Dec 11, 2004 03:35 AM
3.8 & 4.2L V6
Jan 23, 2003 10:01 AM
bigsnag
Nov 22, 2001 10:35 PM
