Help needed
Old May 9, 2012 | 08:10 PM
Bonanza35's Avatar
Bonanza35
Help needed
After second chance I got my glow plugs. Is there a difference between 86 e350 glow plugs and F350 86 glow plugs. I looked up the number of mine and it said 86 ford f350 6.9. I have a van and the number is different.
It has the flat top, just don't want to use the wrong one. I have the controller and relay, do the 86 F350's also have that. Mine is the round controller. thanks,
Chet
Old May 9, 2012 | 10:12 PM
84-6.9L's Avatar
84-6.9L
As long as it has the spade connectors you are golden. ZD1-A is what you want ZD9 plugs have the bullet connector. There is no difference between 250/350/e series plugs.
Old May 9, 2012 | 10:13 PM
87crewdually's Avatar
87crewdually
First, did you read through this yet: https://www.ford-trucks.com/forums/9...old-style.html
86 down should all be the old cotroller that screws into the head using the blade style connector on the glowplugs and 87-up uses the solid state controller with bullet connectors on the glow plugs.
Old May 10, 2012 | 12:08 AM
Bonanza35's Avatar
Bonanza35
Thanks guys. I got these with my IP. They shorted me first then sent them out. Its funny because they show different ones for 86 F350 then they do for the 86 E350. It dose have the right connector on it, so I guess I'll use it. Oh they are DRX or wellman, I couldn't get the motorcraft ones at the time and didn't see the site on here where to get them till they where ordered. They are suppost to be military grade and made in the USA. Thanks,
Chet
Old May 10, 2012 | 12:14 AM
tecgod13's Avatar
tecgod13
If I were you, I'd send them back and get Motorcraft/Beru plugs.
Old May 10, 2012 | 05:35 AM
tjc transport's Avatar
tjc transport
i ain't rite
don't use those glow plugs. they are garbage and will burn out within a month or so.
motorcraft/beru ZD-1 only.
Old May 10, 2012 | 05:29 PM
Bonanza35's Avatar
Bonanza35
Thanks for the input Tom. I knew that, I just couldn't find them local at the time.
Chet
Old May 10, 2012 | 05:51 PM
tjc transport
i ain't rite
rock auto has them for $9.10 each.
RockAuto Parts Catalog
if you need the truck, run the wellmans till the beru's come in, then change them and either keep the wellmans for spares in case something happens to the controller and messes up the berus, or sell them.
Old May 10, 2012 | 06:05 PM
Bonanza35's Avatar
Bonanza35
Thanks again Tom. That is the cheapest I've seen them yet.
Chet
sawmaned
May 11, 2017 12:53 AM
Bonanza35
15
Apr 26, 2012 12:41 PM
86 6.9crew
Nov 17, 2010 12:39 PM
78sharpshooter
Sep 2, 2009 09:08 PM
JakeSherlock
27
Apr 17, 2009 11:16 PM
