Valve body
Do you still have the instructions? They give you a range to drill. Seems like they give a recommended setting for a diesel. I drilled the wife's somewhere in the middle of the range. I've driven in others who drilled it to the max. Not a whole lot of difference I could tell when you make such a small change in the diameter of the hole.
If Jody really adjusts his tuning based on such a small difference in hole size, I'd ask him what size hole he recommends for what you're wanting.
wildstang
06-19-2009 10:34 PM
