Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
.080-.096 drill
Old May 27, 2004 | 07:00 PM
dieselstroke's Avatar
dieselstroke
Question .080-.096 drill
I may or may not need a .080-.096 drill for drilling exhaust holes in my
valve body. I am installing a shift kit it say's that I may or may not have
to drill holes, there may already be a slot in there? Anyhow to the point,
what fractional size drill bit is going to fall into the .080-.096 inch catagory.
It can be any size in between, but not less than .080 or more than .096.
At least that's what the instruction's with the kit say.
Old May 27, 2004 | 07:23 PM
Torque1st's Avatar
Torque1st
Posting Legend
5/64" = 0.078125" or 3/32" = 0.09375" or 2MM = 0.0787" Drill bits usually drill oversize. You can also buy letter and number size drill bits at a good hardware store.
Old May 29, 2004 | 01:08 PM
dieselstroke
thanks for the reply, I got 2 3/32 drills from the machine shop i work
at, i should have just asked one of them guy's. I measured of them with
my digital caliper and it was .092, which is within tolerance. So I have
my drill's now!
Old May 29, 2004 | 03:38 PM
Torque1st's Avatar
Torque1st
Posting Legend
You might want to start with a 5/64" and try to see how it shifts. If it is not what you want you can use the 3/32" drill size.
