egr issue
Old May 9, 2012 | 04:30 PM
cooperdawg234's Avatar
cooperdawg234
egr issue
06 f250 6.0... removed egr cooler welded up both ends and reinstalled. When towing heavy load and using tow hall, after towing for several miles i sometimes get a very rough idel when coming to a stop. After
acceleration the rough idel goes away and may not happen again for several days. Truck runs out great other wise.
Any ideas or thoughts??
Old May 9, 2012 | 06:20 PM
powerstroke72's Avatar
powerstroke72
Moved to the 6.0L Powerstroke Diesel forum.
Old May 9, 2012 | 08:25 PM
BLADE35's Avatar
BLADE35
Welcome to FTE CopperDawg
So the egr cooler is welded did you leave the EGR Valve installed in the intake and also keep it plugged in
Was it doing this B4 you welded the egr cooler shut????
Might want to start thinking about a ScanGaugeII or Gauges being an intermittened isue its going to be Harder to figure out. So it would be good to Have a Gauge so you can check somethings out when it does act up. And in the meantime we can start checking sensor/Actuator operating Values
Check for DTC/codes it may have one even if CEL is OFF
Now how about some service history
Oil Change (Must have OEM Oil Filter Cap)
fuel Filters
stuff like that
Old May 9, 2012 | 09:16 PM
cooperdawg234
never acted up b 4 the egr was deleted. all filters have been changed
MoreBoostPlease
Jul 11, 2013 01:58 PM
Bayou Burt
Aug 5, 2011 06:30 PM
Randman58
Aug 13, 2010 06:14 PM
theskyisoutthere
13
May 1, 2007 11:43 PM
