upgrade an open diff?
Old May 9, 2012 | 11:36 AM
Spyderjohn's Avatar
Spyderjohn
Is it possible to convert an 9" open diff to a Trac-Lock by replacing the "Hat" and installing new guts? (i.e. a Trac-Lock master rebuild kit)
Figured since I have my 3rd member torn apart I might as well entertain all options.
and if so has anyone done it?
I know I should just go out and buy one but that's not how my rat brain works.
Old May 9, 2012 | 12:01 PM
arctic y block's Avatar
arctic y block
Just weld up the spiders.
Old May 9, 2012 | 12:06 PM
Spyderjohn's Avatar
Spyderjohn
That'd be the redneck solution. I'm going for a level slightly above that. It's still gotta be drivable around town without bucking like a ill tempered mule.
Old May 9, 2012 | 12:51 PM
cobraguy's Avatar
cobraguy
Nope you need the trac lok carrier
Old May 9, 2012 | 08:05 PM
arctic y block
I'm just funnin with ya. But it works for a while.
Old May 10, 2012 | 08:31 AM
66crawler's Avatar
66crawler
We installed a "miller" locker in my friends Toyota and its worked great for a long time and its strictly a desert vehicle. But for street use I would suggest a Eaton or Detroit locker, Trac locs are ok but not ideal, if you don't mind the rear end being locked in full spool then buy a spool for it.
Old May 10, 2012 | 08:44 AM
Mikulh's Avatar
Mikulh
Look up a product called Powertrax. I think they're made by Richmond. They replace the spider gears in your open carrier to make it function as a locker. You can install one without messing up the mesh of the gears so they don't have to be re-setup. I have one in my '67 mustang. It works well, but you will hear it clicking as it unlocks in turns.
Old May 10, 2012 | 08:11 PM
sgettin's Avatar
sgettin
i'm a complete and utter novice in this regard but also google detroit truetrac. been wanting one for the front diff on my 4x4. kind of spendy for my budget at around $400.00 if i remember correctly.
Chris Braun
Mar 17, 2013 12:28 PM
bearster18
Jul 18, 2012 03:47 PM
skyfox10
17
Mar 16, 2010 09:39 PM
rugermack
Sep 5, 2007 02:21 PM
Brian429
1997 - 2003 F150
Dec 7, 2005 12:17 PM
