Dash Lights
Old May 9, 2012 | 11:08 AM
Jarrod Blouin's Avatar
Jarrod Blouin
Dash Lights
How to switch the bulbs? How to take off wiper, light *****?
1985 F250
Old May 9, 2012 | 11:48 AM
82f100460's Avatar
82f100460
You have to be able to get to the back of the instrument cluster by removing it to replace the bulbs. It is not difficult but there are several steps to doing this.
In removing the instrument cluster, you will have to remove the ***** anyway. They are held on by a spring clip. You will see a small slot where the **** meets the shaft, You have to get something in there to push the clip toward the ****. This will relieve the spring tension on the shaft and then they will come off. Don't force it or you will pull the clip out of the **** and will likely not be able to be reused.
For the headlight switch, you can also reach up under the dash and find the headlight switch. On the bottom side of it, you will find a small button. Push in on this and the entire shaft will come out of the switch. This will also turn on the headlights so I recommend disconnecting the battery first.
With all the steps it takes to remove the instrument cluster, it would be worth it to go to a parts store and get either a Haynes or Chilton manual. It will step you right through it with pictures. Look at them both to see which one you like better. I personally like the Haynes better.
Hope this helps and welcome to the Forum
Old May 9, 2012 | 05:49 PM
Franklin2's Avatar
Franklin2
Don't forget to disconnect the pointer for the auto tranny if you have one. This thing is very easy to break and then you do not have a pointer for PRND2L.
Old May 9, 2012 | 08:53 PM
82f100460's Avatar
82f100460
That's a good point Dave. Jarrod...there are several other things listed in the manual you need to do such as disconnec the spedo cable.
I do what to clarify one thing though, you are talking about the illumination lights right? And not the indicator bulbs such as the seat belts, blinkers, etc...
Those can be accessed from the front if that's what you're referring to. After you get the front besel off you will see how to get to those pretty easy.
But if its the Illumination bulbs...then the cluster needs to come out
Dirtay Don
Jan 3, 2018 08:42 AM
85AustinTucker
Nov 4, 2013 07:48 PM
cordino
Sep 18, 2009 12:04 PM
Pastorjoel
Electrical Systems/Wiring
Feb 15, 2006 05:54 PM
h kreis
May 16, 2005 01:27 AM
