Sponsored by: Real Truck
2006 f250 tire and wheels
Old May 7, 2012 | 07:52 PM
FORDf250XLT's Avatar
FORDf250XLT
Does anyone know the size of the factory tires and wheels? how big can I go with out needing to lift my truck? What about with a 2" leveling kit?
Old May 7, 2012 | 09:48 PM
StumpJumper00's Avatar
StumpJumper00
/As far as factory size mine came with 265/70/17 I am not sure how big you can go but I would like to know.
Old May 8, 2012 | 11:42 AM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
Factory sizes were:
265/70R17 (~31.5x10.5")
275/70R18 (~33x11")
275/65R20 (~34x11")
How big is going to depend on what kind of wheels you're using. I run 34x11.5" stock with no rubbing, but 35x12.50s rubbed with a 2" lift because the wheels pushed the tires further out. Assuming stock wheels, I'd say 34.5x12" (or a metric equivalent) is a conservative "safe size" guesstimite that would work on the majority of the trucks out there without modding. Factory 17s are 7.5" wide, factory 18s and 20s are 8" wide, so a 12" tire is pushing the edge of what the rim can handle.
Old May 8, 2012 | 03:22 PM
redford's Avatar
redford
FTE Leadership Emeritus
With the stock 2007 wheels, I went to a 285/75R17E BFG T/A KO. It is about 1 inch taller than stock. You should talk to your tire shop, but most shops are hesitant to put anything wider than a 285 on the stock rim. Some will go to a 305, but not many.
allingeneral
Mar 20, 2010 05:50 PM
bmxstreet15
Mar 11, 2009 01:18 AM
Insane Wheeler
Aug 29, 2008 11:12 AM
bkvanbek
Oct 4, 2007 08:47 PM
dockrocker
Oct 31, 2006 04:14 PM
