2003 Escape catalytic converters
Bringing and old thread back from the dead...
I have an '02 Escape XLT V6. Had the front cats gut into the back one going down the interstate. I'm sure you know the story by now. Anyway, a crisp $600 later Midas had me back on the road with an Escape with only TWO clogged catalytic converters now - after they quoted me $1900 for the front two cats alone.
Needless to say I am planning on doing the install myself. I have some mechanical knowledge, but I was hoping to get a step by step from someone who has been through this before. Any piece of knowledge is appreciated! I am planning on buying the Evan Fischer bolt on cats, for both the radiator and firewall side, and I will be doing this in my garage.
I'll just throw in my $0.02
When mine went, the radiator side CAT blew out and plugged the main one. The rest of the exhaust was not looking so hot and needed replaced for the most part so I replaced the entire system from the Flex joint back. I figured I would do the fronts when the weather was better (no garage, and a driveway that's a hill).
Long story short, I have one blown CAT and two good ones.....and NO CODES. No CEL, and it runs great.
I'm not sure why having a hollow front CAT doesn't cause a code, but I'm not going to complain about it either. It passed NYS inspection and that's all I really care about. I do like the "new sound" and kinda wish the rear was hollow too......
Last edited by got2bjoester; 05-07-2016 at 07:16 AM. Reason: Can't spell for carp.
We did not replace the rear engine cat as it was not damaged so I can't comment on that task. I would guess removing the UIM would ease access to the manifold bolts from the top, attacking from top and underneath would be required.
The rear cat was a piece of cake to R&R with no surprises.
To be honest, the job was easier than I had first guessed. There were no real surprises. Of importance to me was getting the spark plugs done to prevent damage to the new cats. Anyone with good basic mechanical experience should be able to do it.
