u-joint question
Old May 7, 2012 | 07:03 AM
RiverRouge73's Avatar
RiverRouge73
u-joint question
73 250 4x4 highboy 360 and NP435. I just had tranny rebuilt (not me...way beyond my skill set) and notice vibration at 50-56 mph. Got under truck and only thing I see is that u-joint is out of phase. I know from hooking up my tractor PTO this is a no-no, and this forum seems to support that, too. Question: How do I take shaft off at u-joint? I've never done this, but looks like 4 nuts holding u-shaped half rings. The shaft looks like two part, short smaller side near to tranny, so I assume I pull it down, pull the end off, rotate it 90 degrees, and slip back on, then re-attach after lining up tranny side. Right? If this is correct, do I need new washers or lock/split washers when I replace nuts? Last thing- how heavy is the shaft? I don't want to be surprised with a bonk in the head either...I'm lucky enough to do pretty much any work just lying on the ground under the truck. Thanks, y'all.
Old May 7, 2012 | 09:32 AM
mark a.'s Avatar
mark a.
You are saying the cross heads don't line up ? If it ended up that way then someone had the slip yoke apart, I couldn't imagine any driveshaft builder would have welded it up that way. Yes take the 4 bolts off slide the slip yoke back and it comes right out, It's no heavy at all. Once you get it out if your lucky your slip yoke collar threads on and you can get it off and find the origional position it was in. Some slip yoke collars are pressed on if yours is then I'd just take it to a shop that builds shafts and have them fix it.
Old May 7, 2012 | 10:29 AM
bamaf150's Avatar
bamaf150
This link goes into detail, maybe it will help:
http://jniolon.clubfte.com/driveline...nephasing.html
Make sure you chock the wheels when you get ready to pull the shaft as it will roll without it.
Old May 7, 2012 | 11:08 AM
montana_highboy's Avatar
montana_highboy
Originally Posted by RiverRouge73
I just had tranny rebuilt (not me...way beyond my skill set).
Did you have a professional shop do the work? if so, they should know better than to re-install the u-joints out of phase.
Old May 7, 2012 | 11:48 AM
crazy96863's Avatar
crazy96863
Driveshafts are lighter than they look. Becareful you dont over compensate for the weight and bump into a crossmember or something... They dent pretty easily.
Old May 7, 2012 | 02:02 PM
RiverRouge73
As you guys mention...the yokes are not in the same plane, so I guess I'll give it a go at correcting this. It makes sense that that's the cause of the vibration. Like I said, I'm not too skilled, but I noticed that right away, since its the first thing I make sure not to overlook on my tractor pto. But those are quick connector shafts, which are self-explanatory how to remove in two seconds. Anyone got an answer about if I need lock washers when I put the nuts back on?
Yes, or so I thought. It causes me some concern.
woodsmoke
Dec 29, 2016 06:12 AM
woodsmoke
Dec 28, 2016 04:13 PM
96f150
1997 - 2003 F150
Aug 12, 2012 06:06 AM
cabloom300
18
Aug 30, 2011 05:45 PM
charlesvalentine
Oct 2, 2003 07:16 PM
