A/C kicks in/out
A/C kicks in/out
My A/C unit runs cold for about 5 minutes at a time and then kicks out. Was recharged last year and just the other day ran for a good 30 minutes ice cold! If it was leaking refrigerant wouldn't it eventually just not work at all? Could something else be causing the compresser to kick out?
A/C kicks in/out
Probably the low-pressure switch causing it to cycle. Put a gauge on it.
Eventually, yes. Sounds like you're getting there bit by bit.
There are any number of other things that could cause it, but low refrigerant is the most likely.
A/C kicks in/out
Yes, a low refrigerant level will cause your AC to stop cooling. In my case, it was merely the AC cycling switch on the compressor that was bad. You can check it with a jumper wire from the battery. I will go through 2-4 switches per year on my Z-71, so 1 per two years on my Ford ain't bad!!
90pioneer
16
06-05-2011 10:37 AM
harry whooo
07-17-2009 10:19 AM
