Ciggarite lighter problem
Old May 6, 2012 | 10:52 PM
joel79ford's Avatar
joel79ford
My Ciggarite lighter dosent work on my 79
I havnt really tried to fix the problem(didnt know what was wrong)
O today i Decided to try to fix it
I tested all my fuses, All of them worked?
SO i took out the ash tray and took the sending unit(i think thats what its called)and found this
Only one wire hanging from it? Isnt there more?
Is that wire on it positive or ground?
And i have no idea where it hooks up to, im just sitting here scratching my head?
Help anyone?
Old May 6, 2012 | 10:54 PM
joel79ford's Avatar
joel79ford
oh and, i dont want to fix it so i can lit ciggarites, im not even old enough to buy them lol
I'm buyying a GPS soon so i can keep track how fast im going
Old May 7, 2012 | 09:19 AM
Oldbone's Avatar
Oldbone
That is the positive. It grounds to the dash through the case. Hot wire usually runs with the radio wire harness back to the fuse block. If the fuse is good and you have a good ground at the dash (ie tight no corrosion around hole) then its prolly shot. They sell them at any auto parts store. Just make sure it is same diameter.
Old May 7, 2012 | 11:08 AM
joel79ford's Avatar
joel79ford
So can i just hot wire the cable to the radio somehow?
Or maybe even the brake?
Oh and do i also need a ground somewhere, or just positive?
Old May 7, 2012 | 11:11 AM
bamaf150's Avatar
bamaf150
Have you tried the gps app on a smart phone? A friends Mom's kia speedo went out and she had a trip planned, speedo is some elec thing at rear of tranny, I told her about the app and she used it to set her cruise control until she could get it fixed. Nice looking truck BTW, love that paint scheme.
Old May 7, 2012 | 11:15 AM
Oldbone's Avatar
Oldbone
just need 12v positive.
Old May 7, 2012 | 06:03 PM
joel79ford's Avatar
joel79ford
I don't have internet onyx phone -__-
and thanks
Old May 7, 2012 | 06:05 PM
joel79ford's Avatar
joel79ford
So where could I hook This cable at?
So there's no negative at all?
I'm getting confused.
Old May 7, 2012 | 06:20 PM
jim collins's Avatar
jim collins
See if you can find a large green wire close by. I just hooked mine up and it just plugged in . I haven't got to check it yet because my truck is still taken apart. You should have a fuse for it,don't want to start a fire if it shorted out .
It's grounded when you fasten it to the metal dash, no ground wire.
Old May 8, 2012 | 04:47 PM
joel79ford's Avatar
joel79ford
Oh ok
Can i just send the wire to the fuse?
Old May 8, 2012 | 04:59 PM
Oldbone's Avatar
Oldbone
yes you can. should be a fuse already labeled cig or ltr. But any will work. should also be a spade clip or two on the fuse block you could use. they are there for addons
Old May 8, 2012 | 06:03 PM
joel79ford's Avatar
joel79ford
Do you know around what size gauge should work this the one I have?
is 14 to big?
Old May 8, 2012 | 06:25 PM
devino246's Avatar
devino246
is 14 to big?
Check this out
spidk43
Electrical Systems/Wiring
Jun 7, 2006 09:02 AM
timberwolf-man
Dec 6, 2005 02:49 AM
MJD
Mar 23, 2004 01:13 PM
trailrunapipe
1983 - 2012 Ranger & B-Series
Sep 25, 2003 07:56 PM
king_nothing351
Dec 21, 2002 11:27 AM
