would a dana 60 from a 1989 7.3l idi f350 fit under there?
Yeah it will fit. Y ou just have to make sure you get the track bar and braket from the 350. If you can do a D60 swap, that would be your best bet in my opinion.
I just swapped that bracket 5 days ago. I wouldn't call adding a lift to the ttb fixing a problem. It may cause a whole new world of them. The one on there now lasted 17, 18 years. I'd either get a new one from Ford or a member here or do the D60 swap if you are able to.
I couldn't get to the nuts on the vertical bolts with the axle stub in place(mine was the bracket holding the passenger side). So I ended up taking the springs loose from the beam and pulling the outer stub from the inner stub and setting the whole damn passenger side beam on the ground. Then I was able to access the bolts. It's a 15mm head between the crossmember and oil pan that you have to hold. Don't cut them because you'll never get new ones in there.
Unfortunately for you, the driver's side beam has the diff in it and it is heavy. I did my bracket R&R and had a lovely assistant lay on the creeper and guide the stubs together while I tried to manhandle the hub/beam/axle assembly. It worked but took a lot of spit, grunts, and bad words. And get you an alignment afterwards.
