Wildman Chip Question
Old May 6, 2012 | 03:19 PM
FLcontractor's Avatar
FLcontractor
I recently purchased and installed a Tony Wildman 6 position chip and absolutely LOVE it! I am blown away at how my truck performs while towing and cruising around town. My question to anyone who has/had a chip is What were the differences between the econo/daily settings and the light/heavy tow settings. I can feel a difference between the light/heavy tow but not as much between the econo/daily settings. Does anyone have any suggestions on the best way to use the different settings?
Thanks guys
Old May 6, 2012 | 06:36 PM
JOHN2001's Avatar
JOHN2001
Your economy setting should give you a nice crisp petal to get you up to speeds faster and efficently. As far as the daily setting goes..... I have no idea I have a DP, call Tony and ask or email them.
As far as tow tunes go the more your towing the less your HP levels will be at. For instance if you tried towing 15000 pounds in an 80 economy tune your EGTs would go threw the roof. You would want to be in a low tow tune like 40T, it changes the shift parameters timing and fueling strategies.
Hopefully that helps you out a little
Old May 6, 2012 | 07:32 PM
F350-6's Avatar
F350-6
Light tow will give you more power than heavy tow. As mentioned, it's about keeping the EGT's lower.
Daily driver should have a tad more get up and go than the economy setting, but they are pretty close to each other.
1L243
Apr 14, 2011 06:30 PM
tallguy
Jun 12, 2008 07:44 PM
tallguy
Jun 12, 2008 04:17 PM
Rich in CO
Dec 27, 2005 06:01 PM
The Gunny
Computer Chips & Tuners
Jun 1, 2002 06:04 PM
