Mouse in the cab - how'd he get in?
Old May 11, 2012 | 05:36 AM
ncranchero's Avatar
ncranchero
I see no way of replacing the cow-things without at least removing the bottom fender bolt and seeing if you could persuade the fender out enough to get your hand in there. They're attached with "Christmas-tree" type push-pins. Nor have I seen anyone reproduce them.
Old May 11, 2012 | 07:29 PM
Eddiec1564's Avatar
Eddiec1564
This is from a 87 cab, in 95 they may have made it solid.
For my mice problems, I recrute a non poisionus snake and let it go under the hood. That got them out quickly and never came back for years!
Old May 11, 2012 | 07:55 PM
thechief66's Avatar
thechief66
Originally Posted by ncranchero
Not being able to come up with a part number got the best of me so I pulled one off.
Engineering number E0TZ1002854AA. I think the part number is E0TZ1002207A "Tube Cowl Side Vent Drain" but cannot confirm that.
Engineering #E0TB-1002854-AA
FORD part #EOTZ-1002207-A
Unfortunately, obsolete from FoMoCo.
No dealers show any on the locator.
Old May 11, 2012 | 07:58 PM
Midnite1987's Avatar
Midnite1987
I just have a mouse trap on the passenger side floor lol. I'm at 3 this week... The truck is better at catching mice then the dog... Or the cat for that matter lol
Old May 11, 2012 | 08:08 PM
madpogue's Avatar
madpogue
Yeah, we've had a trap set in there for a week or so; no takers yet. Got a couple of a different kind I'm gonna try this weekend.
Eddie, your pics have me confused. What angle is it from? Is that from in the cab, or the outside of the truck, or what?
Old May 11, 2012 | 08:10 PM
Midnite1987
I used a piece of Reese peanut butter cup....lol (I was on a drive and didn't want to buy a jar of peanut butter) and it worked great lol
Old May 11, 2012 | 08:57 PM
ctubutis's Avatar
ctubutis
Klimesh Motor Sales Calmar, IA 52132 Tel. 563-562-3241 shows having 1.
Old May 12, 2012 | 03:53 AM
ncranchero's Avatar
ncranchero
They list them here and price them @ checkout so maybe they have a few.
EOTZ-1002207-A - Ford TUBE - WATER DRAIN
Old May 12, 2012 | 01:45 PM
Eddiec1564's Avatar
Eddiec1564
That's the metal plate access for the drain. The photos are of the driver's side looking from the driver seat area. The dash is totaly removed fro
m the cab. The ECU sits right in front of the silver panel behind the parking brake lever. The newer trucks may not have that access anymore.
Old May 12, 2012 | 03:02 PM
madpogue's Avatar
madpogue
Thanks Eddie, that puts it all in perspective. Yeah, on the later cabs, there's a whole 'nother bracket/structure along the left side, that the parking brake attaches to; looks like it's part of what stiffens the cab/firewall. The PCM is behind that. But then behind that is the actual inner wall of the cab, and even with the PCM shoved out of the way, I'm not seeing any other access panel back there.
Indeed, peanut butter, almond butter, tahini (sesame butter) all make good mouse trap bait. I'm hoping the two I caught in the nest watching TV were the only ones who'd set up housekeeping.
Thanks for the leads on the parts. Wow $20+ for a P####!! Geez, there are some neighborhoods in Detroit where.... oh never mind. Anyway, I actually don't think they're torn. I think they've just kinda lost their shape, and the rubber has just pulled away from the edge of the hole, so new ones will prob do the same thing. I was able to reach up from the outside, and get some duct tape on 'em to hold the edges to the edges of the hole.
Thanks again for all the help; hopefully this saga is over....
Old May 21, 2012 | 06:37 PM
madpogue's Avatar
madpogue
Saga continues, kinda. Doing some bodywork on the other truck (RCLB), pulled one of the fasteners off the cow-[ahem] on the passenger side (it was loose), and this piece fell out.
Part # EOTB-15020A50-AA ; nothing comes up on a search. Anybody know where it goes? We haven't pulled the interior panel yet.
Old May 21, 2012 | 07:20 PM
ncranchero's Avatar
ncranchero
I expect it goes under the cowl panel as an access cover for a wiper mount. I pulled the cowl panel off of one of mine last week and can look if nobody comes up with it. Too late tonight though. There is a access hole for the upper door hinge that looks like that on some models but not sure if it applies here or if it would try and fall out the cow- (ahem) if it came loose.
Old May 21, 2012 | 07:27 PM
  #28
Diesel_Brad's Avatar
Diesel_Brad
Yeah. That goes on top, right under the cowl
Old May 21, 2012 | 07:43 PM
  #29
madpogue's Avatar
madpogue
You mean the body-painted steel panel, that the wiper arms go through?
How does that mount, BTW? It's loose on the ECLB truck.
Old May 22, 2012 | 03:30 AM
  #30
ncranchero's Avatar
ncranchero
Yes, under that. There are 4 (+/-) screws accessible through the round holes in the top of the panel and 6 or 8 that you have to access with the hood raised, that also attach the rubber strip.
Not exactly the one you have (this is a 87-91 I think) but a good illustration:
