Well just took our first trip in our new to us 2006 F250 Lariat towing our 3 horse gooseneck trailer.
We made it 130 miles to our destination and 100 miles back.
When climbing a hill, suddenly lost power and the "Wrench" came on.
We truly limped home with quite a pucker factor, and when I tried to read my ScanGauge 2, "NO CODES"!
The temp gauge on the ScanGauge never went over 200 degrees.
The dealer had replaced the oil cooler and 3 injectors before I bought it and the EGR valve had been replaced twice prior according to the OASIS Report.
I can't tell you how uncomfortable it is when you are praying that the truck doesn't grenade with 3 horses on board.
I will be calling the dealer first thing Monday morning but for now any thoughts?
Greatly appreciated,
Just make shure the numbers are taken exactly like this
Truck in PARK OR NEUTRAL all times during test
ECT at 190* or close to
KOEO=Key On Engine Off =record value
Low Idel (truck idel on its own)=record value
High Idel (2500RPM)=record value
Values below are given in this order^^^Left to right
Did you make it Home yet??? if not dont turn it off for KOEO Values get them Later
I need to find BARO code to so if anyone has it Post Please and thanks
Dont feel Bad about that SGII for the 160.00 it Pretty well covers the engine and some of the trans.
Just need to get the SGII Programmed and know what to watch for
Dealer read the code and it was the turbo that caused the problem. Sooted up and in need of cleaning. They are going to service the turbo, clean the EGR valve and check ohter serviceable components.
I have another trip to Vermont this weekend and I will keep my fingers crossed.
Thank you all for all your help!!!
Question about code scanners Will the Snap-on MT2500 read
the wrench codes along with other things?
Mine has the CAN adaptor and the 2 sets of keys needed for this truck.
Or is there a better one that does not cost what the truck costs?
Thanks
Sean
