on my f100 74 360 4speed 2wd
the cluster that on my truck shows 85 mph
its bad. so i found one on ebay it shows 100 mph
iam not sure if the cluster was the one that was on it or not.
loooking at one on ebay looks the same as the one that on it from the back of the cluster..
do you think it work ?
the one on ebay say came off 77 f100 360
also on back of cluster . it has 3' plug that plugs into cluster. on mine i don't see another plug for fuel. does that plug works for fuel as well ? or is their another plug or wire controll the fuel for the cluster.
is it a plug and play???...I thought I heard someone saying that the hi-beam indicator is located elsewhere between the 2 clusters??..i never took the time to do a side by side comparison...if you do the swap let us know for sure
That should only matter if you have idiot lights or gauges.
Bill, wasn't the issue w/ the high beam indicator more than just a guages vs. lights ???If I recall it was more of moved elsewhere on the cluster and not wired correctly, a guy changed it out and made up his own indicator light
