74 cluster
Old May 7, 2012 | 11:21 PM
PapaBearYuma's Avatar
PapaBearYuma
If the instrument clusters interchange, will their seven different printed circuit boards also interchange?
Will their four different cluster backs also interchange?
Are you aware that the POS composition cluster backs used 1975/79 can TURN TO DUST before your very eyes?
Are you aware what FoMoCo did to solve the problem?
Thanks, Bill, for the additional cluster info!
As far as the composite material going to pieces - yeah, I know all about that! I'm still picking pieces out of my dash and carpet. I pulled the assembly out to change a bulb and it disintegrated in my hands. I believe the composite material has been replaced by plastic.
Currently, I have two bulbs in the brown truck that don't light up because the backing is gone and the bulbs no longer lock down. Gonna be searching for another cluster back soon.
Old May 8, 2012 | 01:31 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
As far as the composite material going to pieces - yeah, I know all about that! I'm still picking pieces out of my dash and carpet. I pulled the assembly out to change a bulb and it disintegrated in my hands. I believe the composite material has been replaced by hard plastic.
1981: Ford came out with hard plastic cluster backs for Econolines, these were also the service part replacements for the crappy compositions.
E1PZ-10848-A .. Hard Plastic Cluster Back-Use with Oil & Amp Gauges / Obsolete
Applications: 1975/79 F100/350 / 1975/91 Econoline / 1978/79 Bronco.
CARPENTER NOS OBSOLETE PARTS in Concord NC has 567 = 800-476-9653.
E1PZ-10848-B .. Hard Plastic Cluster Back-Use with Oil & Amp Warning Lights / Obsolete
Applications: 1975/79 F100/350 / 1975/86 Econoline / 1978/79 Bronco.
CARPENTER has 96.
Old May 10, 2012 | 05:27 PM
FordRun's Avatar
FordRun
cluster works mine shoed 85mph and other one i got was 100mph
lolocal
Nov 28, 2018 10:50 AM
nut4brend
Sep 17, 2014 02:03 PM
bigcountry25
2004 - 2008 F150
Aug 25, 2014 08:33 AM
racer2012
Nov 23, 2003 10:44 AM
