Front hubs
Old May 5, 2012 | 03:05 PM
Awmjr05's Avatar
Awmjr05
Front hubs
I have a 2006 F250.When I put my truck into 4hi or 4low the air starts blowing out of the defrost vent. Has anyone had this problem before?
Old May 5, 2012 | 04:11 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
You have a bifg leak in the vacuum somewhere. Check near where the lines hook up to the front wheels. Vacuum is what switches your 2wd to 4wd and back. Did you run in the snow/ice this past winter?
Old May 5, 2012 | 06:24 PM
BLADE35's Avatar
BLADE35
Bud is right on the VAC Leak
Vac lines control the Hubs and the Heater vent selection
Old May 5, 2012 | 08:31 PM
Awmjr05's Avatar
Awmjr05
Front hubs
No snow and ice for me, live here in Florida. The vacuum lines look good going to the hubs. Any other suggestions?
Old May 6, 2012 | 09:08 AM
strokin83's Avatar
strokin83
I'd check the vacuum switch on on the passenger side fenderwell. It's a little box with a electrical plug in and two vacuum hoses coming out of it. It has a white top I think. Anyways I've had 2 of these go bad on mine and both times it did what you are describing.
jstihl
17
Jan 18, 2016 09:25 AM
bigcountry1009
Jul 23, 2014 05:34 AM
kconrad
Oct 24, 2012 03:19 PM
beemr
Jun 6, 2007 12:56 PM
SteveH-CO
Sep 8, 2005 11:58 AM
