Scan Gauge install trouble
Old May 5, 2012 | 09:38 AM
Corner Gas's Avatar
Corner Gas
I installed my scan gauge the other day and all went good except for the FICM. I can't get it to show any reading? Any suggestions or am I just missing something?
Old May 5, 2012 | 10:28 AM
Rusty Axlerod's Avatar
Rusty Axlerod
No reading? Double check numbers?
glruff's Avatar
glruff
FTE Leadership Emeritus
Did you program it in the Xguage settings?
Old May 5, 2012 | 11:27 AM
Corner Gas's Avatar
Corner Gas
Twice
Yes, the other gauges I installed all work. I dropped a zero off the mth code and now I have a reading of 3.06
Old May 5, 2012 | 11:33 AM
Rusty Axlerod
These work for me:
KO=KEY ON LI=LOW IDLE HI=eHIGH IDLE OR=OPERATING RANGE
FICM Vehicle Power (Volts) (Should be 12 Volts, should not drop below 10.25 for more than 60 seconds, or 9.0 for 4 seconds. TSB 09-24-03)
TXD: 07E02209CE
RXF: 0462450906CE
RXD: 3010
MTH: 006401000000
NAM: FVP
KO=12.0 LI=14.0 HI=14.0 OR=10.5-15.5
FICM Logic Power (Volts) (Should be 12 volts)
TXD: 07E02209CF
RXF: 0462450906CF
RXD: 3010
MTH: 006401000000
NAM: FLP
KO=12.0 LI=13.5 HI=13.5 OR=10.5-15.5
FICM Main Power (Volts) (Should be 47-48) Your FMP should never dip below 45. If it does, your FICM is toast and needs repaired or replaced. Check when cold
TXD: 07E02209D0
RXF: 0462450906D0
RXD: 3010
MTH: 006401000000
NAM: FMP
KO=47 LI=47.5 HI=47.5 OR=40-52 (yes, that is what it says from Ford)
Old May 5, 2012 | 04:46 PM
glruff's Avatar
glruff
Eric, those are the same codes that work for me also.
Old May 5, 2012 | 08:04 PM
Corner Gas's Avatar
Corner Gas
I will give those numbers a try tomorrow. Thank you
Old May 6, 2012 | 11:43 AM
Corner Gas's Avatar
Corner Gas
Third time is a charm, apparently I am dislexic. I got a zero and a one mixed up in the mth code.
Old May 6, 2012 | 11:59 AM
amdriven2liv's Avatar
amdriven2liv
I'm hitting easy street
Welcome to both clubs! One, the club of Scangauge II users.
And the other, "fat fingers typing in the codes" club. I checked one gauge at least 5 times, and still didn't see it until I deleted and re-entered it.
Have fun with it. Don't let it drive you crazy.
Old May 6, 2012 | 02:22 PM
Corner Gas's Avatar
Corner Gas
I guess I needed a day to see my error, it was very obvious when I went to edit it.
Old May 6, 2012 | 04:29 PM
Rusty Axlerod
Glad ya got it figured out before you started pullin your hair out!
1BadHabit
All Other Items for Sale
Jan 1, 2018 05:51 PM
snakedoc
Aug 21, 2012 11:01 AM
scottddove
Mar 7, 2012 10:54 PM
Shaneb75
May 12, 2011 02:25 PM
jimm66
1997 - 2003 F150
Jun 1, 2008 08:48 PM
