Pyro not working
Old May 5, 2012 | 02:32 AM
jlwoods99's Avatar
jlwoods99
Pyro not working
I believe its a banks, on my 92 F 350 2 whl drive dually with a sidewinder. can I get a probe somewhere or does it have to be a banks and is this most likely what is bad?
Thanks
Jim
Old May 5, 2012 | 09:31 AM
farmert's Avatar
farmert
There are 2 different probes, and I'm not sure which style Banks uses. I would contact Banks to get the correct one.
Old May 5, 2012 | 09:35 AM
whiteboyslo's Avatar
whiteboyslo
Here you go:
https://www.ford-trucks.com/forums/1...questions.html
And yes, it's most likely the probe. There is a way to check the gauge that involves using an ohm meter on the back of the input probes, but I forget exactly how it goes.
Also, you do NOT have to buy the probe direct from Banks. Shop around. You should be able to find it cheaper pretty much anywhere else.
Mike
Old May 6, 2012 | 09:56 AM
jlwoods99's Avatar
jlwoods99
Thanks, I started reading your posts this am. I may not have run the truck hard enough yet to get it to register. I've only run it home from when I bought it abouts 16 miles.
Jim
Old May 6, 2012 | 11:48 AM
'94IDITurbo7.3's Avatar
'94IDITurbo7.3
what is it doing (or not doing)? the gauge should register as soon as the engine starts. should fluctuate based on throttle input.
Old May 6, 2012 | 12:17 PM
jlwoods99's Avatar
jlwoods99
Its not moving at all, It didn't appear after I ran it home that it came up at all. I was thinking it should come up some in the 15 or so miles I drove it home. But I really had no idea how low it would stay not pulling any load.
Jim
Old May 6, 2012 | 12:24 PM
'94IDITurbo7.3
yep, sounds like the probe.
Old May 6, 2012 | 05:46 PM
86f250XLT-4x4's Avatar
86f250XLT-4x4
SORRY wondering what would cause a pyro to read way hotter than what the truck is actually running because if my exhaust temp was reading what the pyro says my engine would be a puddle in the oil pan... or on the side of the road... i know the gauge itself is a bullydog... and it has an electronic control box that the probe hooks too.... idk what could be going on with it... when i first got it...(buddy gave it to me) it all worked great... now.. the gauge pegs out and it reads up to like *2200 ... something like that
Old May 6, 2012 | 05:58 PM
'94IDITurbo7.3
check the grounds
dman255
6.4L Power Stroke Diesel
Sep 25, 2012 05:34 PM
cdiddy
Sep 27, 2011 04:42 PM
2010F350
WTB - Parts & other
Nov 9, 2010 11:18 AM
btsb032304
Apr 28, 2008 12:14 AM
