Getting ready to upgrade my transmission from the early job 1 set up to the job 2 set up and just want to make sure I'm on the right track.
1) New job 2 pan (deeper to accommodate the filter)
2) Internal filter element
3) Gasket
3) Fluid
The last item is the trans lines, I've read that to replace the lines I have to loosen the motor mounts and lift the engine about 2 inches to get to the cooler hose fittings,,,,rather not do that if possible.
Is there a better way? Could I not Cut the line before and after the external filter and splice in either a braided line and fittings or just use transmission cooler hose and clamps in place of the external filter?
Thanks in advance for all your advice.
I've got some pics of my current mods in my gallery now.
