Sponsored by: Real Truck
How to increase towing
Old May 4, 2012 | 05:17 PM
jackson1981's Avatar
jackson1981
Hi i have a 2008 f350 srw i just bought a 40' trailer and it weights 17000 # loaded. Finding it a light hard to tow. Once it get moving it tows great. But leaving the city it is hard starting off at lights any ideas how to make it better on starting. It is a stock 350 with 3.73 gear.
Old May 4, 2012 | 05:24 PM
alchymist's Avatar
alchymist
"Mifflin Clay"
Change from 3:73's to 4:30s would be a start
Old May 4, 2012 | 05:39 PM
Kajtek1's Avatar
Kajtek1
Let me guess? Automatic transmission? Had the same problem when my manual F450 blew the differential and I rented automatic F550 with 6l. The 1st gear in those is pretty lousy.
Would your truck be 4WD you could use low gears in the city.
Changing differential seems to be your only option, unless you can change to smaller wheels.
Old May 4, 2012 | 07:24 PM
Tom's Avatar
Tom
Which engine do you have? The 6.4L PSD? A regear may help but you're really pushing the limits of an SRW truck. Have you considered upgrading to a DRW F350 or F450?
Old May 4, 2012 | 07:27 PM
rjfetz1's Avatar
rjfetz1
You must have a gasser. Tuner from 5-star gave my 5.4 much more low end.
Old May 4, 2012 | 08:08 PM
dkf's Avatar
dkf
I don't care if you have a 250 or a 550, a 17k lb trailer is going to slow it down more than a little bit. Has to have a healthy pin weight as well. But like crazy said we got to what engine it has.
Old May 4, 2012 | 11:49 PM
galaxie641's Avatar
galaxie641
Shouldn't be much of an issue with that weight if it is a diesel, even the V10 isn't that bad, that isn't a lot of weight in the grand scheme of things. If you are trying to drag race at lights pulling it I don't know what to tell you.
Old May 5, 2012 | 01:35 AM
Kajtek1's Avatar
Kajtek1
Don't know how much Ford improved automatic transmissions over the years, but once again, the F550 with 6l and automatic was very lousy on 1st gear. Beside being slow on intersections, it would not pull out of motel driveway with 14k trailer. I had to back up to flatter spot and give it some momentum. At the time I was blaming 6l for low torque, but lately I bought 2000 F250 with 7.3 and automatic and have to switch to low gears maneuvering truck alone on my driveway.
Must be the nature of the beast.
Old May 5, 2012 | 06:42 AM
ruschejj's Avatar
ruschejj
If you are really serious about this and your truck really won't move, with the understanding that you really have too much weight for that truck, you could do what has been suggested.
Go to a 16" wheel.
Change the rear diff to a 4.10.
Have the trans. Serviced (new fluid, flush, calibration)
I have moved up to 16,000 with my truck and it really was not that bad. Starting from a stop on a hill is a bit scary but given time it will go. The '08 diesel is a very strong machine and I really can't imagine that you would be having that much trouble unless your expectations are a little too high. The 5r100 torque shift is a solid trans. Too, one of the best.
But, if you have a v10 or the 5.4 I could easily see that things would be worrisome. They would still do the job but there is much less torque available.
Old May 5, 2012 | 06:50 AM
senix's Avatar
senix
I have a F250 with the 6.4. You are only 3K more than me. I have an auto with 3.73 gears as well. It does just fine.
So gasser?
Old May 5, 2012 | 11:02 AM
Quad Racer's Avatar
Quad Racer
If you want to tow that heavy I'd also suggest a brake upgrade as well whether you have the diesel or gasser.
A tuner would be a nice addition to the gear swap as well.
Old May 5, 2012 | 12:08 PM
tinfish's Avatar
tinfish
I have an 06 F250, 5.4, manual trans, 3.73 gears. The heaviest I have towed was over 12k pounds, and although the truck moved it ok, really it was too heavy. It was just a few miles on flat roads with little traffic, so I felt ok with being overweight, but braking and handling really suffered, and honestly it was not a safe situation. My point is that getting the trailer moving is just one issue; the safety concerns come from how well the entire package handles and stops.
Old May 5, 2012 | 01:05 PM
Tom's Avatar
Tom
Remember that an F-550 wouldn't have any easier of a time stopping that trailer. Trailer brakes are responsible for stopping the trailer, and the truck's brakes are responsible for the truck and any tongue weight placed on it. Sounds to me like you had either lousy trailer brakes or nonfunctional ones.
Back when I drove trucks I once had to pull an empty 53' van to a shop to get the brakes fixed. The slacks were backed off all the way and therefore there were no trailer brakes. Empty the trailer weighed around 13,000 lbs, and I was towing with a Kenworth T-600 rated at 80,000 lbs GVWR. It was a SCARY ride without trailer brakes. My point here is that it doesn't matter what you tow with, a trailer without brakes is a scary thing.
Old May 11, 2012 | 09:46 PM
snoway63's Avatar
snoway63
I have a 05 F350 V10 and have no problems towing trailers in the 12-16 thousand lbs range and with plenty of torque with the tow haul mode, what do you have in the 08
FORD1976
May 25, 2019 07:36 AM
Vinford
6.7L Power Stroke Diesel
Jul 31, 2016 09:00 PM
goatram
15
Dec 15, 2014 02:33 PM
jettex
Mar 4, 2014 06:17 PM
mrfoyds
Colorado Chapter
Mar 10, 2008 09:55 PM
