PLEASE HELP
Old May 4, 2012 | 03:06 PM
MarauderV8's Avatar
MarauderV8
PLEASE HELP
Hello, the F150 of my brother has the follow diseases:
  • rough running
  • ticking noises
  • low mileage per gallone
  • blue smoke out of exhaust after start
i have ordered the cam phaser, hope, that will be the reason.
But today, my brother means, i have to do a test drive, because the truck has no power. and really, feels like missing of one or two cylinders.
Very bad performance. Is it possible, that the reason are the phasers?
thank you for help!
Old May 4, 2012 | 03:53 PM
Squirrely418's Avatar
Squirrely418
blue smoke in exhaust is the valve guides going bad.
Rough idle can be many things. No spark, injectors, fuel pressure, etc...
ticking noise is either lifters or exhaust leak. Provided it's not the injectors you're hearing
Not good news either way.
Old May 18, 2012 | 04:07 PM
MarauderV8's Avatar
MarauderV8
Today, i replaced the cam phasers, was a big extent of work.
The result was, that the noise is better, but not good enough.
The ticking in front of bank 1 is disappeared but now is at bank 2, i guess at the 7th or 8th cylinder a loud ticking, probably already before.
Furthermore the truck has no power, if i give "kick down", the truck will not accelerate enough.
I changed all spark plugs, at two of them (7th and 4th cylinder) the negative electrode was slightly broken an as i pulled with my finger at the electrode, it was abrupt. What can be the reason for that? Never seen before. They was CHAMPION spark plugs!!!
PLEASE TRY, TO FIND A SOLUTION WITH ME!!!!
Old May 18, 2012 | 04:13 PM
pdqford's Avatar
pdqford
Check Engine Light on? Codes?
Old May 18, 2012 | 04:14 PM
MarauderV8's Avatar
MarauderV8
no light, no codes! and if i connect the IDS Tester from Ford, there are no faults too
street591
13
Feb 17, 2016 12:00 AM
makuloco2000
2004 - 2008 F150
Sep 7, 2015 04:23 PM
edsjr
2004 - 2008 F150
Jan 28, 2013 02:55 PM
ke7gpu
Oct 7, 2009 12:24 PM
dvldog458
33
Oct 10, 2003 03:13 PM
