Smashed Spark Plugs (351W)
Old Oct 6, 2009 | 04:46 PM
ke7gpu's Avatar
ke7gpu
My truck started smoking recently kinda out of no where. It is a blue/grey smoke like oil, not the pure white from a blown head gasket. It doesn't start with a big puff of smoke as I'd expect with a worn engine, but rather it starts clean and then as it warms up it starts smoking. I don't notice it running down the road (though it might be) but it is especially bad at idle.
I took out my spark plugs looking for some insight and found that two of my spark plugs were damaged. Number 8 had no gap and was very black and wet while #3 was completely destroyed and also black and wet.
Compression in #8 seems ok though I didn't have a gauge it will blow my finger off when I cover the hole. Number 3 on the other hand has low compression. I can feel it moving air so I don't think it threw a rod but I've been wrong before. Here are some links to pictures of the plugs.
Picasa Web Albums - David - Truck Stuff
You can't see it real well but it looks like something is repeatedly hitting them like there might be something in the cylinder. The third plug is a representation of what the rest of them look like (normal).
Anyone have any idea what is wrong and what caused it?
Old Oct 6, 2009 | 05:27 PM
Conanski's Avatar
Conanski
Not good, you may have cracked a piece off a valve and it's bounced around in there for a while before getting blown out the exhaust. The valve would have cracked from a persistent lean condition on that cylinder.. possible dirty fuel injector. In any event looks like you're pulling a head or two to figure out why compression is low and what's causing the damage.
Old Oct 7, 2009 | 12:24 PM
ke7gpu's Avatar
ke7gpu
Thanks, I kinda figured that it was a valve issue. I got the engine pulled, I'll let you know what I find.
mrekab
31
Feb 13, 2015 08:29 PM
Acidic
22
Feb 21, 2014 12:10 AM
declinetostate
Jun 7, 2013 07:07 PM
retro48/52
13
Jul 30, 2011 07:56 AM
ronnshf
Modular V8 (4.6L, 5.4L)
Oct 29, 2009 05:57 PM
