Dp tuner help
Old May 4, 2012 | 02:34 AM
Tormz's Avatar
Tormz
Dp tuner help
I just put it in and it is on the stock setting now won't start. Did I do some thing wrong
Old May 4, 2012 | 02:36 AM
BigAlsPSD's Avatar
BigAlsPSD
Are you getting a Wait to Start light? Sure you cleaned the contacts on the PCM well, and not too much? Are you getting the little dot in the lower left?
Old May 4, 2012 | 06:59 AM
Ponyboychris's Avatar
Ponyboychris
The keys were NOT in the ignition during any of the installation, right?
Old May 4, 2012 | 09:30 AM
Tormz's Avatar
Tormz
I'm getting the dot no wait to start and the keys were not in
Old May 4, 2012 | 09:50 AM
Smokiesman's Avatar
Smokiesman
If you remove chip can you start the truck???
Smokie
Old May 4, 2012 | 10:00 AM
Tormz's Avatar
Tormz
Trying that now
Old May 4, 2012 | 10:04 AM
Tormz's Avatar
Tormz
Yes starts fine
Old May 4, 2012 | 10:06 AM
ggirten's Avatar
ggirten
It's not showing the 0 setting is it? That is the no start setting. Also, make sure your wires are plugged in correctly. I installed the one to my gauge up side down and it wouldn't start.
Old May 4, 2012 | 10:13 AM
Tormz's Avatar
Tormz
It was in 1 stock and would not start just crank
Smokiesman's Avatar
Smokiesman
HMMM! Looks like sumthin not quite hooked up right!!
Smokie
Old May 4, 2012 | 10:17 AM
Tormz's Avatar
Tormz
Aw great. Second time with a chip that didn't work. Other chip I ordered they sent blank
Old May 4, 2012 | 10:49 AM
BigAlsPSD's Avatar
BigAlsPSD
If you aren't getting a wait to start I would venture that the J3 connector is either not cleaned enough or has had too much material removed.
Old May 4, 2012 | 11:08 AM
Tormz's Avatar
Tormz
I made sure it was clean then added material to make sure secure connection
Old May 4, 2012 | 11:15 AM
BigAlsPSD's Avatar
BigAlsPSD
When you retinned the contacts any chance some solder "jumped the gap"?
Old May 4, 2012 | 11:19 AM
Tormz's Avatar
Tormz
I triple checked but it is clear
