Dp tuner help
Old May 4, 2012 | 11:29 AM
HH60FE's Avatar
HH60FE
Tormz, it just has to be something with the connection. Somehow the 'puter isn't reading it if the truck starts without the chip in. Give Dianne a call if your sure your connected right.
Old May 4, 2012 | 12:45 PM
Tormz's Avatar
Tormz
I did call and there closed. I have checked every connection and they are all good
Old May 4, 2012 | 01:00 PM
dsquared's Avatar
dsquared
Tormz:
I see you are in California (I think it's not Canada)....where about are you? Maybe someone close can come by and see... you know, another set of eyes....
I'd do it if you're close, but I'm at work now, and I have some maintanance work when I get home...Tomorrow may work...
Old May 4, 2012 | 01:26 PM
Tormz's Avatar
Tormz
I'm in the Fairfield/ Vacaville area
Old May 4, 2012 | 01:35 PM
JOHN2001's Avatar
JOHN2001
Did you scrape off the connection on the tuner and use acetone or like product on it to clean it? I had a problem but my truck would start but not change tunes even though it did on the tuner
Old May 4, 2012 | 01:43 PM
Tormz's Avatar
Tormz
I cleaned it and retinted it
Old May 4, 2012 | 09:43 PM
HKusp's Avatar
HKusp
Check that cable. It will connect in both directions. Flip it over. I had a similar problem when we did my dad's.
Old May 4, 2012 | 09:54 PM
Tormz's Avatar
Tormz
As in what side ic to the chip and what side to controller. I think they have groves to keep it right side up
Old May 5, 2012 | 11:32 PM
sand_fiend's Avatar
sand_fiend
Yes, i think it will plug in both ways. its kinda deceptive. try and flip it over on the pcm.
Old May 5, 2012 | 11:35 PM
sand_fiend's Avatar
sand_fiend
I believe on the program switch it will only plug in one way because of the notch's . But on the pcm board ( the chip ) will plug in both ways..
https://www.dp-tuner.com/index.php/a.../aitfile_id/5/
Charlie01
Apr 22, 2011 09:02 AM
cowboybootlegger
65
Jun 18, 2010 01:30 PM
RedBoat
Mar 15, 2010 11:47 AM
rodolan
Jul 16, 2009 06:38 PM
crazymut
Apr 7, 2008 11:33 PM
