Dually wheel studs
Old May 3, 2012 | 11:44 PM
RLDSL's Avatar
RLDSL
Dually wheel studs
What size wheel studs do I need to buy for a 92 dually hub with a 10.25 axle, or are they threaded in studs that I can ( with any luck at all ) remove from the old hub and reuse ?
Thanks------Robert
Old May 4, 2012 | 07:53 AM
farmert's Avatar
farmert
The studs should be reuseable, unless they are damaged. Just drive them out, and drive them back in the new hub.
Old May 4, 2012 | 05:10 PM
tecgod13's Avatar
tecgod13
x2 on reusing them, but becareful not to screw up the threads. Thread a nut on the end of the stud and use that to press the stud out. Probably can be done with a decent sized hammer (definitely use the nut as the target, not the end of the stud), though a shop press is much easier. If hammered out, you can use a nut to suck them back into place.
sjwelds
May 12, 2016 08:40 AM
cpinter10
Jan 13, 2011 10:08 PM
Explorer220K
Jan 9, 2011 08:09 PM
texastech_diesel
Jun 22, 2010 12:09 PM
truk68
Jan 24, 2010 12:12 PM
