'75 F100 axle
Old Dec 24, 2006 | 05:10 PM
OldFords's Avatar
OldFords
'75 F100 axle
A little help, please.
My son's truck is a 1975 F100 4x4 auto/360 w/Ford 9-inch. The passenger-side rear axle is bent. I have picked up two axles only to find they don't fit.
They were all the right length with the correct spline count. The biggest problem seems to be the axle diameter where the bearing seats.
The bearing outer diameter (OD) is the same, but the inner diameter (ID) is different. The diameter of his axle is a bit largerr than the diameter of the axles I have found.
Are the 'standard' F100 axles smaller than the F100 4x4's? Do I need to find a F250 axle?
Any help is appreciated.
OldFords
bad attitudes
Old Dec 24, 2006 | 05:21 PM
Mil1ion's Avatar
Mil1ion
The info required is on the axle ID tag.
Old Dec 24, 2006 | 09:32 PM
Matts72's Avatar
Matts72
The bearings on these axles must be pressed on. 9" axles are 28 or 31 spline, most F100s got the 28 spline axle. An F250 has a Dana 60 or 61 rear axle and its 35 spline and completely different than a 9" axle.
