Hey Gary,
I can't believe you don't have this info yet. I wondered out to the garage and pulled the flywheel I purchased for my project. It's a 351W based 408. The flywheel thickness appears to be just about 63/64". I didn't have a caliper, but my trusty combination square came up between 31/32" and 1.00". Does that help at all?
Ron
Just so you know (as it affects dimension #1), the flywheel on this 302 has been refaced & measures .942" from the rear (friction) face, to the front machined face, which pulls up to the crankshaft.
Also, if it makes any difference, this is an E7TE block, with a one-piece rear seal crankshaft.
Originally Posted by Gary Lewis
Specifically, I'm looking for:
The distance from the rear face of the flywheel to the rear face, the tranny-mounting flange, of the block
The distance from the rear of the pilot bearing to the rear face of the block.
1. The distance from the friction face of the flywheel to the machined bellhousing surface of the block is 1.208"
2. The distance from the rear of the pilot bearing to the same bellhousing surface of the block is .64" - BUT this is with a pilot bearing that sits .157" proud of the crankshaft rear face.
I have another new pilot bearing here that only sits .102" proud - so there can be some variation between bearings.
Pilot bearing dimensions are -
OD - 1.38" (shoulder dia. is 1.44")
ID - To suit .669" dia. pilot tip
Length to underside of shoulder - .575"
Underside of shoulder to outer end, as mentioned above.
Hope this gives what you need Gary.
Ken, that's exactly what I was looking for. Thanks! May not get the dimensions into CAD tomorrow as my wife and I are going to do something together, whatever we want to do, but will soon. THANKS!
Hey Gary,
Ron
Ron - Sorry, somehow I missed your input. Thanks, it always helps to have confirmation.
Hey Gary,
Having my post missed is not a problem. Breaking my kneecap, Saturday, now that's a problem. Think Mr T's prediction for the fight in Rocky III, looking directly into the camera and saying, "Pain". That's where I live now. I am so thankful for narcotics. Shouldn't need surgery, but won't be doing much work on the truck for probably about 6 weeks.
I'm looking for some measurements from a 302/351W with a true flywheel on it, not a flexplate. The measurements are to determine if a small-block input shaft for a ZF5 would resolve some of the issues when mating one of the 460 versions of the ZF with a 351M/400.
Or, if someone has just the flywheel, I need the distance from the rear of the crank pocket to the rear face of the flywheel. IOW, the thickness of the flywheel less the depth of the crank pocket. That's because I have a 351W which I can measure and, with your dimensions, figure it all out. Oh yes, I'd like the dimensions on the pilot bearing as well.
Thanks in advance!
Just making sure you know this; A small Ford zf has a 1 1/16" shaft with 10 splines while the 460 zf has a 1 1/4" shaft with 10 splines.
Hey Gary,
Later,
Ron
OUCH!!! How did you do that?
Yep. Actually, what happened is that Stang/Don suggested that another input shaft might have the splines in a different place. So I did some checking and found that there were three different shafts:
And, since the diesel variety is said to have a 4.14 first gear as opposed to the 5.72 of the two gas configurations, I'd say the 34 tooth shaft is for the diesel. That would make one of the other two for the 460 and the other one for the small-block. But, could the small-block one be 2 14" longer?
Anyway, that's the impetus for this exercise. I'm not sure I want to disassemble the tranny to change the input shaft, but I would like to know what the options are. So, I'm using these dimensions on CAD to try to figure it out.
