over-boost
Old May 2, 2012 | 08:46 PM
briancooper's Avatar
briancooper
over-boost
I just deleated my egr, truck ran great for 400 miles then fell on its face. Now I hit 28psi before I cross the street and loose all power. I cleaned turbo, intake, map, ebp sensor, and the vgt selonoid. Lost now any help welcomed.
2003 6.0 300k miles.
Old May 2, 2012 | 09:01 PM
BLADE35's Avatar
BLADE35
What you getting for MAP and Baro and (EBP if it comes up 03 thing there) at KOEO
wondering if a sensor got taken out during the cleaning
probabbly good idea to make shure they FULLEY Plugged in too
you left the EGR Valve installed and still plugged in right?????????? hope you didnt throw it out anyway
Old May 2, 2012 | 09:10 PM
flamebuster's Avatar
flamebuster
Did you do the turbo re-learn? That is a key part of post cleaning..
Old May 2, 2012 | 09:14 PM
briancooper
i checked all plugs and have the latest flash so ebp shouldnt matter.
i havnt relearned turbo but i cleanrd it after the over boos started
Old May 2, 2012 | 09:17 PM
BLADE35's Avatar
BLADE35
Great Idea on the turbo relearn Doug
and whats MAP and BARO at KOEO
briancooper
yea egr is still pluged in and map has some strange readings. boost goes to 22 psi then jumpes to -14 and lowers to -8 if you stay in throttle. soon after turbo hoses blow off
Old May 2, 2012 | 09:19 PM
briancooper
ill run out and check baro and map now
Old May 2, 2012 | 09:26 PM
BLADE35's Avatar
BLADE35
So your using a SGII ok
theres a newer Gauge to program so it dont go negative fix that later
BOOST is just a MAP reading Minus Ambeint Pressure
1 more time Post MAP and BARO readings at KOEO and Low Idel and High Idel(2500rpm) MAP will or should be the only one that will change at diff rpm
MAP & BARO need be within 0.5psi at KOEO the PCM uses these to figure Turbo Vein position/Boost output
briancooper
manifold pressure 14.03 psi
boost .03
scaner doesnt show baro per say
Old May 2, 2012 | 09:28 PM
briancooper
ill go check at 2500
Old May 2, 2012 | 09:36 PM
BLADE35's Avatar
BLADE35
boost .03
You must program BARO
trying to find the X-Code Hold on
But 14.03 PSI MAP is going to be close or right on
But the BARO Sensor sets the Baseline pressure for the PCM Odds are slim its going to be a Bad Sensor but it must be rulled out
Scan for DTC
Any CEL??
Old May 2, 2012 | 09:37 PM
briancooper
map at 2500 is 23.4 and i cant find baro
Old May 2, 2012 | 09:39 PM
briancooper
im using a bluetooth scanner i might need to buy one.
i notice a new code
maf volume low. showing 0 cfm on gague
Old May 2, 2012 | 09:40 PM
briancooper
no cel lights
Old May 2, 2012 | 09:42 PM
briancooper
codes p0102
p0505
p0649
p1000
